Remote stick removal confirmed
2547 8 2016-11-21
Chaser720
Flight distance : 400190 ft
Copied from over at MavicPilots. Any thought from DJI staff on this one? I'm a little scared to be forceing those in and out of the remote with calibration being sensitive.
Thread link, video and picture from thread below. Not mine, just summarizing.
http://mavicpilots.com/threads/r ... val-confirmed.1681/
2016-11-21
ferrari-458-ut
Yeah I'm not going to be yanking my in and out like that.
2016-11-21
Shill Slayer
You're going to remove them a few times until they become loose & will no longer stay put.  Then you'll wind up losing one or gluing them in so they stop falling out!
2016-11-21
method007
Flight distance : 110449 ft
Yea DJI has been pretty consistent that they are not removable.  Only a few early remotes made it out to the public with the removeable ones.
2016-11-21
DJI LA Support
Shill Slayer Posted at 2016-11-22 05:48
You're going to remove them a few times until they become loose & will no longer stay put.  Then you ...
This is correct. The sticks are not designed to be removable and forcing them out could weaken the integrity of the stick.
2016-11-21
Chaser720
method007 Posted at 2016-11-21 18:12
Yea DJI has been pretty consistent that they are not removable.  Only a few early remotes made it ou ...
Sounds to me like they were all built the same way but the early production ones didn't have the sticks "pressed" into place.
2016-11-22
Chaser720
DJI LA Support Posted at 2016-11-21 19:44
This is correct. The sticks are not designed to be removable and forcing them out could weaken the ...
Is the concern here the strength of the stick or possible damage to the controller?
2016-11-22
DJI LA Support
Chaser720 Posted at 2016-11-22 06:14
I'm not sure what the engineering decision was, but constant removal may weaken the holes in my experience.
2016-11-24
fans302fcd3a
Flight distance : 228169 ft
DJI LA Support Posted at 2016-11-24 20:48
Perhaps threaded inserts and replacement sticks with thread would be a solution.
2016-12-11
