DJI Mavic Battery Charging Hub not working?
274933 274933 2016-11-21
fanse02a0c93
Hi all, I just received my Mavic with the fly more combo and when trying to use the battery hub to charge all three batteries at once, it doesn't look like anything is charging. None of the battery's status lights come on, but the small led light on the hub is switching between red and green. I don't see a description for this red and green status in the manual. What am I missing? Thank you for your help.
2016-11-21
cluc
Flight distance : 85682 ft
No photo, no video, no help.
2016-11-21
Harbourside
Flight distance : 6467 ft
It does not charge all batteries at once, it charges them 1 at a time, starting from the one with the most charge.
Cant help with the LED because as you say that light sequence is not in the manual.
Just check all connections and maybe try 1 battery at a time to start with, then if it works add the other batteries, are all batteries on the same firmware ?
2016-11-21
Could you please make a short video of the issue?
I'll help to check it.
2016-11-21
Travelling Dron
same problem here it's a rock solid red light
2016-11-21
RichJ53
Flight distance : 1837356 ft
Maybe you can try just plugging 1 battery into the hub and see if the charge starts. then add another battery at a time to see if you can identify the issue.
When you press the button on the battery does the LED's light up?
Will the battery charge using only the stock charger directly?
take a photo or video of the issue
Rich
2016-11-21
DJI Natalia
Flight distance : 318 ft
Travelling Dron Posted at 2016-11-22 12:35
It's brand new and this is the first time you use it, right?
Have you tried to change another power socket, clean the connectors and check again?
If it's still solid red, please upload a short video for further evaluation, thanks.
2016-11-23
fans3b15e824
Flight distance : 11322 ft
Has anyone figured out how to fix this issue? I am having the same problem. I only see a solid red light on the charging hub. I have tried connecting the battery on different ports and nothing changes.
I can upload a video if necessary but I don't see how it can help with the diagnosis. I plug it on, a solid red light on the hub appears and stays there regardless of how many batteries are attached to it.
2016-12-2
Marktho1
I sent mine back to be replaced. The response was everything is working fine and they shipped it back to me missing the plug.. I had a spare plug at the house so I plugged it up to the hub and it was green for a few seconds and went back to solid red. even trying to plug straight to one battery is useless.. If I use the hub on the car charger it works fine. There is a problem with the ac adaptor but DJI refuses to listen so I am stuck with no way to charge the batteries except through the car charger. very inconvenient.
2016-12-2
Drmerlin
Flight distance : 2441663 ft
I know this might sound a bit out of the box but are you sure you have the power connector plugged in at the bottom of the unit rather than trying to connect the hub using the USB lead????
2016-12-2
fans3b15e824
That actually worked Drmerlin! I was just about to contact DJI to send it back until I read your comment.
Thank you so much!
2016-12-3
ZUB
I perhaps have a similar problem.
Battery charges fine directly plugged into the power adaptor:
It does not charge when connected with the intelligent charging hub:
The light turns red and does not do anything.  I have FMC and have tried with the other two batteries and many other combos.
2016-12-3
Alien_robot
Flight distance : 291519 ft
I have the same problem
2016-12-3
No Man's Drone
Flight distance : 301545 ft
Wow. Same problem with mine and my neighbor's charging hub. What's up with this, DJI?
2016-12-3
No Man's Drone
Drmerlin Posted at 2016-12-2 13:58
I know this might sound a bit out of the box but are you sure you have the power connector plugged i ...
How do you even connect the charging hub using the USB lead???
2016-12-3
No Man's Drone
No Man's Drone Posted at 2016-12-4 02:11
I stand corrected. There is a micro usb port on the hub.
2016-12-3
No Man's Drone
I got it to work now. Apparently the power outlet that I was using before was weak.
2016-12-5
Heavysledz
Flight distance : 819491 ft
The input power requirements are: 100-240VAC @ 1.4A 50-60Hz
I don't know many homes, that would have an issue providing power within this range......
2016-12-5
Anthony566
Flight distance : 2488944 ft
The led colour combinations are in the Battery Charging Hub guide on page 7 .....
2016-12-5
No Man's Drone
Heavysledz Posted at 2016-12-5 11:54
Beats me. I tried the power outlet outside my shop and it worked. Inside my office, it wouldn't. If I plug in something in that outlet, it works like a lamp or my phone charger. Anyway, problem solved. Not sure why there are still others experiencing it.
2016-12-5
Heavysledz
No Man's Drone Posted at 2016-12-5 19:53
interesting....any chance you have a voltage meter that you can check the voltage at both outlets to see if there is a difference?
2016-12-5
Drmerlin
No Man's Drone Posted at 2016-12-4 07:11
There is a rubber retainer on the side of the dock with a USB connector
2016-12-6
ScXSN5EFH9Mk
Czechia
Same red light issue!!! Has the problem been solved? Is there a firmware upgrade??? thank you!
2016-12-10
Slypilot
Czechia
DJI Natalia Posted at 2016-11-23 11:37
Hello,
please can you provide some answer? thank you
2016-12-10
DJI Natalia
Slypilot Posted at 2016-12-11 02:39
Hello,
Sorry to hear about that, the firmware for charge hub is not available recently.
According to your description, the battery is fine, have you tried different power supply? since you can get the info in the manual: solid red means there is something wrong with power supply or battery error.
If you have tried that and problem persists, then it needs to be sent in for further evaluation.
2016-12-10
Ice
Hello !
Same problem for me..
I have to plug/unplug all many times to make it working
2016-12-10
Ice
Ice Posted at 2016-12-11 08:38
Hello !
Hello !
Just replaced it and it's working now
2016-12-14
Heavysledz
Ice Posted at 2016-12-15 01:20
Hello !
what did you replace?
2016-12-14
Ice
I've replaced the hub
2016-12-15
Heavysledz
Ice Posted at 2016-12-15 21:20
did DJI send you another one under warranty?
2016-12-15
boostedford
Flight distance : 144478 ft
The manual says the hub can get firmware updates i hooked mine up to DJI assistant 2 and nothing happens it just shows the plug the USB in picture so how do i update it?
2016-12-15
MartenS
Flight distance : 863 ft
Hi Same problem here. the hub is charging the battery's on after the other. and not all at once :-(
2017-3-4
Harbourside
MartenS Posted at 2017-3-4 04:05
That's what its supposed to do.
You need the Advanced Charging Hub to charge more than 1 battery at a time.
2017-3-4
Lukev
Hi all,
So I had a few problems with my multi charger too. Tried plugging in two batteries to it. The hub LED flashed green, with an odd yellow and red also in the mix. Had the batteries on charge for 4 hours and neither charged.
Have read a lot of threads on this and have tried a few things. Have come to the conclusion:
1. There is no firmware update for the hub at the moment
2. plugging your hub into your computer with dji assist wont do anything as there is no update
3. Try changing what socket your have your adapter plugged into
4. I purchased my Mavic from Singapore and thus it came with the two prong plug (I live in the UK which is generally 3 prong)
5. In the UK we have a few two prong sockets for things like shavers and electric tooth brushes. THESE SOCKETS WONT WORK - THEY DONT HAVE ENOUGH POWER EVEN THOUGH THEY SAY THEY DO.
6. I took my power cable from my laptop (3 prong plug) and plugged that into the adapter for the hub. All seems to work fine now
Hope this helps someone
2017-5-10
PanamaJack
Flight distance : 101089 ft
This might be a moot point but I had the same problem and realized that I just had the wires wrong-- you don't connect the micro USB plug into the hub from the adaptor to charge the batteries. Instead, turn the hub over and you'll see there is a female end for receiving the funky mavic battery cord already attached to the adaptor. Plug plug that cord into the port UNDER the hub and it should work, or at least it did for me. Hope this helps, cheers.
2017-6-24
Makuna
I just received mine and I also am seeing a problem.  The light on mine is solid green; but not one battery is above 25%.  The batteries charge fine when directly connected.  But the hub won't charge one, two, or even with three connected.  And yes, the power adapter is connected directly underneath and not by the USB port.
I am going to update all the batteries and see if that helps.
2017-7-13
Flyer_BFK
Makuna Posted at 2017-7-13 17:54
I have the same problem with the hub. Plugged in my three batteries, it only charged one and I noticed it's light had turned red. When tried charging batteries one at a time, that worked but that's not why I paid $55 for a 'smart' (advanced) charging hub.
Now, also, since reading this thread I'm now made aware the BATTERIES MAY NEED FIRMWARE UPDATES! omg.
And links or information on how to do that, upgrade the firmware of the batteries, would be appreciated.
2017-7-14
Poltergeister
So many people have this problem, that it is pretty clear it is a Mavic issue. My hub used to work and now gets the red led (now flashing red). I used to be able to charge single battery without hub, but no longer. It is pretty clear to me that the power supply unit is screwed. What garbage.
2017-9-27
fans8c6a56a9
Serbia
Anybody solved the problem? Mine is green for a second, then turns red, and stays red, no matter if the batteries are connected or not...
2017-10-6
DJ Enertia
Flight distance : 614065 ft
ZUB Posted at 2016-12-3 18:38
I would also remove the plastic from the power transformer to help dissipate heat or it could get too hot
2017-10-7
