indigooo
Flight distance : 178602 ft
Its easy to setup but No succes at all
Activ tack.... objeckt is recognized succesfull and the camera follows ...but if the objekt moves forward ...mavic dosent follow at all ...after a while.."objekt out of range"
terrain track and follow me...same problem...flight mode can be enabled..... but NO follow at all.
position mode is enabled, intelligent flight mode also enabled
gps signal strong
What is wrong, is it my fault... Did I overlook some stupid things ??
Thanks for help
Manfred
# update!
same problem in Wi-Fi mode... tracked me as an object... Camera follows if I go in a circle... If I move away, no reaction !!
I checked if the GPS in my phone works properly, .... Yes it does
