Buzzyone
Flight distance : 4647913 ft
Eikro Posted at 2016-11-28 07:21
From the original post, I quote:
"...she [tech. support representative] stated that you have to do an IMU, gimbal, and compass calibration after each firmware update..."
I never calibrate the IMU after firmware updates, I carry out the update, then carry out a function check on the ground, power up, Manually lift off to about 3 feet, hover, confirm that the hover is stable, perform a 360 degree rotation in both directions allow it to hover, then check right stick commands.
double check the RTH altitudes confirm that the OA is enabled and then go vertical about 30M then carry out a flight test maintaining eye contact.
Never let me down yet. Compass calibration is the only 'routine' calibration I do. Never had any issues. |
