MavicUser
Flight distance : 431417 ft
[size=14.6667px]I remember in the older version of the DJI Go app, the map always defaults to following the aircraft, and shows the line pointing towards "Home". In my flight today, there was no way for me to get the map to follow the aircraft. It seemed stuck at "Home". If I tap on the small map so it expands, there was a symbol I could tap which opened up either "Home" or "Aircraft" symbol. If I tap on the "Aircraft" symbol, the map will shift around and center itself on the aircraft. However, it still does NOT follow the aircraft and simply just stays at that point, so when you fly away from that location, the map is just showing the track of where your aircraft has been.
[size=14.6667px]How do I get the map to follow the aircraft like it used to do?
