HWKIDD
Flight distance : 22877 ft
did you go in the app and look at the compass settings, green yellow or red, there are two compass on this unit, and when one fails the other is to take over, I have seen post, where you look at the compass settings, one will pass and the other did not, I was on my third flight two days ago at my son's house, out in the middle of know where, I did not re calc the compass as it said normal, and I have read so much, where one persons says you should and another says you should not, I really do not know anymore, what is correct, but I dropped down to 1 red bar with 12 being tracked, but then it went back to green in a few seconds, Now I was also flying in beginner mode, as I have not had a drone, since the Vision, and on that drone you did the compass dance before every new location flight, will follow your post, to look for updates, Mine Mavic is one of the first run, was ordered on the first day, and shipped in the first release, but I did not fly it until after the update, so sure hope its not a issue with early production, |
