DJI-Jamie
Flight distance : 112405 ft
Try that and see if it helps. If the issue persists and you just got the unit, you may be within range of an exchange with your dealer. Otherwise, we can have this addressed via a RMA through the North America Repair Center. Just for your information, the P3 Standard's firmware update process starts with updating the RC first and then begins updating the aircraft on its own. If the update process gets interrupted at any point, then it could cause issues. Do you recall if you received an update 'failed' message or did it just stop all together? |
