Switch 1, Position 3: ATTI, Failsafe or Manual
MilspecJSC
I'd like to get some insight on how the community has setup switch 1/position 3 (ATTI/Failsafe/Manual) in NAZA-M mode. Right now, I have mine configured as ATTI but I'm considering Failsafe. I'm not an advanced pilot yet so Manual is not an option for me. I'd like your feedback and any rationalle you care to share.
2015-2-9
Gerry1124
I have mine on failsafe.  It gives me another option of recovery.
2015-2-9
rod
New Zealand
S1 pos3=failsafe for me.
Cheers!
Rod
2015-2-9
PhantomHelp
In Naza-M Mode, S1 position 1 is always GPS. S1 position 2 is always ATTI. S1 position 3 can be either Failsafe or Manual. Unless you have a really good reason to be flying manual, you probably want to choose Failsafe.
2015-2-9
MilspecJSC
Perfect! The three I had hoped to reply, did. Thanks for your advice. Failsafe it is.
2015-2-9
blasco403
I have mine set at Atti for position 3... When I used the NAZA Flight controller on a home built quad, I had it set for failsafe but also changed to Atti for the same reason as below. I programmed a different switch on my futaba transmitter for failsafe - but this is not an option for the stock phantom trans.
I did this so that in an emergency, like GPS issues and phantom wanting to fly away, or having to switch to Atti mode when using ground station to take back control. If it does go from position 1 to position 3 insteasd of position 2, it does not automatically start the RTH function.
I would just shut off my transmitter if I needed failsafe....
Just my 2 cents - since when an emergency happens and you need atti mode, i like the fact that both position 2 and 3 are ATTi.
2015-2-9
Jamie Hellmich
Position 3 set for manual.
2015-2-9
Swerve
Failsafe for me
2015-2-9
kleake.rapfire
Flight distance : 1361040 ft
Position 3 is manual for me.  I can get failsafe by turning off the remote.  I feel better knowing I can fly manual if I need to.  And yes, I have practiced a little bit starting at about 200 ft up.  It's definitely scary and things happen fast, but while practicing, if you get out of control you can turn it back to GPS and it will recover (At least it has for me, and it is impressive how quickly it does).  I want to get good enough in manual that I can fly it if I want/need to.
That being said, I used it the other day.  Was flying at 400ft, had went for a distance out and was on the way back when I realized I was at 20% battery.  I know I would be cutting it EXTREMELY close, so I started descending.  Well, it was only coming down at 4mph......  I'm not so sure I can get down before I run out of battery, so I switch to atti,,,,,, still 4mph........  Not looking good and I'm starting to worry (I was over trees, but still).  I switch to manual, drop throttle and I am now descending at 20mph!!!!  MUCH faster than I intended, but once I was at 200ft I switched back to GPS and landed with 8% battery.  Yes I should have been keeping a closer eye on my battery level, but I was caught up in what I was videoing and lost track of how long I had been there.  Anyway,,,, not the recommended method of descent, but in an emergency, I would rather lose some altitude quickly while I am still way up there instead of a battery shutting down at 100ft!
2015-2-9
MilspecJSC
You make a good point, Kleake, regarding taking full control not only of your descent but to know if all goes south you can still fly the bird. Once I feel more comfortable with my flying skills I will definitely move over to Manual. Thanks for sharing your experience.
2015-2-9
gerd.kockerbeck
Failsafe for me too
2015-2-9
