ofcdduke.att
Hell,
I have the S900 with the A2, Lightbridge, and H3-3D gimbal. Its controlled with the Spektrum DX9. I first had the A2 linked to the DX9 via satellites but I was getting signal loss and failsafe at 1500 feet out. I was advised to use the Lightbridge for video and RC since the Lightbridge was probably interfering with the 2.4Ghz RC control of the satelites. This is where I run into problems.
I hooled up the lightbridge to the A2 and I am able to map the main RC channels and the failsafe, GPS modes, and homelock modes. I was finall able to map the tilt function after combining the GPS, atti, failsafe modes to one switch.
I can see the rc and gimbal control in the LB assistant and the gimbal responded to the control. However when I power cycle, I lose all control. I plug in the A2 and start the A2 assistant and I can not see any of the contol inputs. How do I se the RC control in the A2 assistant and then make adjustments for the IOC and flight modes?
