New firmware for Phantom 3 Pro/Adv has been released.
49964 360 2016-11-28
Hawk Wingover
fans9992c216 Posted at 2016-12-4 13:03
Is followme working again?
Updated without any problems, formated the micro sd card with SDFormatter before downloading the bin file onto it never had a problem useing this software,update took about 15 mins and batteries updated very quickly. Settings still remain , new warning about loose or missing props, now showing latest firmware and app, flys great and no problems with video transmision, useing ipad4 mini with latest software, Hawk
2016-12-4
Weeman
Flight distance : 2186506 ft
666angels Posted at 2016-12-4 09:24
Hi guys.
My son turned off my p3 advanced during firmware v1.10.90 update. Now when i t ...
Just reformat the card and put the new firmware back on , then put it back in the drone and start up , you will get the load beeping while its updates , it will eventually go off when it is updated but may take a while.
You only get the really load beeping when you end the update process early so don`t worry it will stop in the end.
2016-12-4
Shuvo0o
I updated my drone with #1 battery successfully to 1.10.90 but when I changed to #2 battery and was going to update it but it didn't process, I then checked the result on computer it says it was already updated for the #2 battery. That's unusual. Is it normal?
Also I noticed that there's no firmware update for the remote controller. I'll test to fly tomorrow and let you know how it goes.
2016-12-4
Blackzilla1337
DJI Mindy Posted at 2016-12-4 14:00
Please have a try and keep us posted.
i have test it now with the DJI Go App version 2.9.1 but it's not better only the live map is now from google and can be use offline but the video transmission is still very bad. Completly unusable the drone was only 20 - 30m away and still get a bad video stream on my tablet. so i have now contact the dji support and wait now for a answer for my problem.
2016-12-4
Grabo
Flight distance : 26296 ft
Hawk Wingover Posted at 2016-12-4 14:27
Updated without any problems, formated the micro sd card with SDFormatter before downloading the bi ...
Updated both my phantom 3 advances no problems lights on drones go out for a while video links on both seem good but not tested long distance using Ipad mini 2 settings the same in app. Grabo
2016-12-4
Phantomski
Flight distance : 14869882 ft
The battery firmware dos not show in about, does it? I guess i have to go to battery menu on every battery to confirm if the battery update happened?
2016-12-4
HEM
DaveB87 Posted at 2016-12-1 18:45
DJI do battery warmers for the colder months, they only seem to be about 20quid or so..... might n ...
Can someone confirm that the requirement for battery temperature to be > 15C is a feature of the new firmware?
2016-12-4
Skydronezone
Flight distance : 1146473 ft
Shuvo0o Posted at 2016-12-4 15:27
I updated my drone with #1 battery successfully to 1.10.90 but when I changed to #2 battery and was  ...
The update I believe is just for the drone and camera, no update needed for battery
2016-12-4
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Shuvo0o Posted at 2016-12-4 23:27
If your RC currently is running on 1.8.0 mean this is the latest version.....
2016-12-4
mads30
Poland
DJI Mindy Posted at 2016-12-4 10:57
Hi, can you check your current firmware version now?
What mobile device you are using?
Hello, after update to the newest version still cannot get firmware (aircraft/controller) information. I'm using Samsung Galaxy S4(GT-I9505) with 5.0.1Android, and app version is 3.1.0. Now I can connect with aircraft, but I have huge problem with video transmission. Picture is freezing, with long lag, not usable.
2016-12-4
SimonH78
Flight distance : 1452408 ft
HEM Posted at 2016-12-4 17:01
Can someone confirm that the requirement for battery temperature to be > 15C is a feature of the n ...
Yes it is - battery will need to be warmer than 15C to take-off/start ...
2016-12-4
SimonH78
mads30 Posted at 2016-12-4 18:23
Hello, after update to the newest version still cannot get firmware (aircraft/controller) informat ...
Check your settings - as sometimes they revert to default - like the settings for the video "Enable Hardware Decoding" - I have this ON - an "Video cache during shooting" - OFF
Might be this?
2016-12-4
DJmaxOD
SD card errors... my cards all worked before the update..
2016-12-4
DotheMath
Flight distance : 2113 ft
Ran the update this morning, all went well and only took about 20 minutes. Updated the spare batteries, calibrated the IMU and took the P3P for a flight. No problems at all! As a matter of fact, I honestly think it's more stable now than it was with the prior update and all the compass errors I was getting
2016-12-4
Wiebird
Flight distance : 138205 ft
I updated 2 hours ago. No connection on my HTC M9 mobile anymore. Tried my Samsung tablet S2, no connection.
My chinese Teclast Tpad, no connection !!!
This is realy frustating. Checkt all prescribed settings, without results.
log : with strange dates
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.10.0090.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.12.04 20:19:39 =====================
Result: Abort.
any ideas ???
2016-12-4
Wiebird
android versions :
Samsung tablet S2  6.0.1
HTC M9  : 6.0.1
Teclast Tpad : 5.1
2016-12-4
Toelis
Is this update for the remotecontroller too ?
2016-12-4
KuChar
Flight distance : 723156 ft
Poland
The latest firmware for Remote Controller is 1.8.0. Not included in package zip. You must update RC FW using DJI GO app.
2016-12-4
Wiebird
Toelis Posted at 2016-12-4 22:46
As I know its a aircraft and camera-update
I discover that my controller ( connected to my HTC M9 Mobile ) recognises the Mavic device with
signal " Remote Controller signal Weak " . Not any drone is activated and connected !!!
I even have no Mavic drone , my neighbours ether.
2016-12-4
Bobbu8
Hi Guys,
    Very wise NOT to upgrade. I am having all sorts of problems...mainly won't turn on the motors and when you do cannot turn off. Flying a nightmare the drone will increase revs or decrease setting the aircraft up/down without control you really need to be on the sticks, won't hover as steady. DJi you better have a fix I cannot fly my quad. I had a message to calibrate  the sticks which I did but still no good. DJi where are you.
2016-12-4
Wiebird
Issue resolved. In my case ( Samsung and HTC ) Mobile device settings must be : camera PTP ON ( and USB debugging ON ). MTP ON does not work.
and so we are learning every day.
Thanks for your reply
2016-12-4
Naza-PA
Updated and test flew for a 5 mins. Everything looks good. No issues. Noticed, the bird when cold started had a small bit vibration on idle time-to-time as usual for my drone. When in air it is rock steady. After landing it is rock steady on idle as well, not even a tiny vibrations. All looks good. Then flew Mavic and it was good too. Honestly i like to fly both equally, P3A feels like it has more power to overcome gusts of head wind vs. Mavic (make me almost panic on return path due to the head wind).
2016-12-4
Phantomski
No issues after the upgrade, achieved my normal distance, i'd say the video feed was actually more reliable, and I'd swear the motors sounded a bit softer.. not as jumpy... Overall have not seen any ill effects yet.
http://healthydrones.com/main?share=qrUFEn
Winds up to 17MPG gusts!
2016-12-4
Viper989
Flight distance : 891194 ft
endotherm Posted at 2016-12-3 03:39
I updated my machine last night, it went smoothly with no problems.  I noticed a few nice changes.   ...
Hi endotherm ,
You seem to be the only one who pick up on the ''3 seconds before CSC'' .
Can anyone else confirm?
Someone at DJI maybe , as this is big news
Thanks
2016-12-4
mads30 Posted at 2016-12-5 02:23
Could you please find the update log file and post it here?
You could find the update log file by following these steps:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-12-4
DJmaxOD Posted at 2016-12-5 04:23
Have you tried to format the SD card?
2016-12-4
Alberto Pasian
I didn't update the firmware but alas my DJI Go App did self-update to 3.1 (IOS)... is there a way to revert back to the old version app?
2016-12-5
Alberto Pasian Posted at 2016-12-5 17:00
Do you have any problem when using the latest DJI GO version?
2016-12-5
endotherm
Flight distance : 503241 ft
Viper989 Posted at 2016-12-5 16:32
Hi endotherm ,
Go and read post #1, it is in the changes summary that comes with the firmware too.  See note 4.
What’s New?
1. Optimized Flight Restriction Zone management by deleting flight restrictions for some abandoned airports.
2. Optimized HDR+RAW format photos.
3. Improved motor performance to prevent occasional overheating resulting from a motor stall.
4. Slowed motor stopping time to three seconds during flight.
2016-12-5
Weeman
Alberto Pasian Posted at 2016-12-5 09:00
Only if you have the old app saved , it should be on your itunes on your PC/Mac if you haven't updated that too . Just turn off auto updates and delete the new app and then install the old app from itunes . When itunes updates apps on your PC/Mac the old apps go in the recycle bin where you can recover them and save them somewhere save .
2016-12-5
fans66488b86
Flight distance : 728235 ft
Will this firmware work with older Go App versions and older controller versions?
2016-12-5
ImagesByJAS
Flight distance : 286198 ft
SimonH78 Posted at 2016-12-4 13:30
So I now have to keep my batteries in my pocket before I can swap them out instead of leaving them in the case.   Does DJI realize there are folks in the northern and southern hemispheres who actually have winter? I'm not sure why all of a sudden we now have a temperature check before we can take off when we've never had one before??  What changed since the P3 was introduced???
2016-12-5
ImagesByJAS
Alberto Pasian Posted at 2016-12-5 04:00
Short answer is yes..  Do a search for the "Charles method" here in the forums.  Not quick and easy but works.
2016-12-5
ImagesByJAS
DJI Mindy Posted at 2016-12-5 04:28
There's a whole discussion solely on the Map issue Mindy and the switch for Android users from Google maps to maps that are incredibly back level.  Some people (apparently) purchased Litchi just to get google maps back.  Very hard to fly with very outdated mapping..
2016-12-5
ImagesByJAS
Phantomski Posted at 2016-12-5 00:16
Phantomski..
I was looking at the details of the flight record on Healthy Drones and looks like you lost the signal multiple times at a very short distance to home??  Lines P and S??  Were you in an obstructed area?  Just curious as to why a loss of signal at 90 and 10 feet from home point..
A        00m 00s        0.0 ft        0 ft        Mode        Mode changed to GPS_Atti
B        00m 02s        -0.7 ft        0 ft        Mode        Mode changed to AssitedTakeoff
C        00m 02s        -0.7 ft        0 ft        Warning        Return-to-Home Altitude:82FT
D        00m 08s        -0.3 ft        0 ft        Mode        Mode changed to GPS_Atti
E        01m 23s        91.9 ft        171 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
F        03m 01s        392.1 ft        2,210 ft        Data Loss        Downlink data connection lost for 1.4 seconds
G        04m 15s        389.8 ft        3,502 ft        Data Loss        Downlink data connection lost for 2.2 seconds
H        04m 23s        391.1 ft        3,506 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
I        04m 28s        390.1 ft        3,504 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
J        04m 33s        390.1 ft        3,505 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
K        07m 48s        392.4 ft        3,708 ft        Mode        Mode changed to Atti
L        07m 49s        392.1 ft        3,708 ft        Warning        Flight Mode Set to Attitude__Set Flight Mode to GPS to fly safe
M        07m 51s        392.1 ft        3,707 ft        Warning        Flight Mode Set to Attitude__Set Flight Mode to GPS to fly safe
N        09m 08s        389.1 ft        91 ft        Data Loss        Downlink data connection lost for 12 seconds
O        09m 08s        389.1 ft        91 ft        Mode        Mode changed to GoHome
P        09m 08s        388.8 ft        90 ft        Warning        Signal Lost. Aircraft Returning Home
Q        09m 37s        282.5 ft        10 ft        Data Loss        Downlink data connection lost for 28.2 seconds
R        09m 37s        282.5 ft        10 ft        Mode        Mode changed to AutoLanding
S        09m 37s        281.5 ft        10 ft        Warning        Signal Lost. Aircraft Returning Home
T        09m 43s        223.1 ft        8 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
U        09m 48s        173.6 ft        9 ft        Warning        GEO: You are in a Warning Zone (Unpaved Airports). Fly with caution.
V        09m 49s        161.4 ft        9 ft        Mode        Mode changed to GPS_Atti
2016-12-5
Alberto Pasian
DJI Mindy Posted at 2016-12-5 10:28
I haven't yet tried. Can I fly with the latest app and the non-updated firmware?
2016-12-5
Alberto Pasian
ImagesByJAS Posted at 2016-12-5 16:04
Will try. Thank you so much.
2016-12-5
loucos
Flight distance : 423261 ft
Greece
Mindy, hello,
After the update, aircraft version went from 1.9.60 to  version 1.9.60+
Do you have an explanation for this please?
2016-12-5
fans9992c216
Repeating my question:is FOLLOW ME working for Android again,this is very important for me.
thanks
2016-12-5
SimonH78
Had a hover in my lunch hour and seems to be far more "positioned" when hovering  very smooth - impressed, have flown Phantoms a long while , its not my imagination!
2016-12-5
