Mavic Footage Not in SD Card
10003 28 2016-11-29
Federicoli
Hi all,
I shot a couple of videos on water with my Mavic Pro for the last day of my thanksgiving trip yesterday, but when I got home,  only some of the videos appeared in the SD card.
In more details:
1. I had no reception at the place I flew
2. Maybe because of no reception, I did not get any Mavic footages on the DJI app (even ones that appeared in the SD card)
3. I double checked the recording button every time
4. It seems like about 7/10 of the footages I shot were in the SD card, but the rest (2 of my favorites) DID NOT appear.
I'm really upset since I had just returned home this morning and likely will not be able to do it again anytime soon.
Has anyone experienced something similar, and/or found a solution to this problem?
PS Im going to try a file recovery software tonight and see if it works.
2016-11-29
Nees
Flight distance : 80988 ft
Belgium
Were you sure you pressed record every time? If you had no reception, how did you frame your shots?
2016-11-29
Federicoli
I double checked / triple checked every time.  I can't say "definitely" but I am 90% confident.  The stream does not travel through cellular data.
2016-11-29
Federicoli
Nees Posted at 2016-11-29 15:29
2016-11-29
Nees
Belgium
Federicoli Posted at 2016-11-30 02:46
I don't understand. if you have control over your drone, you have an image on your screen.
2016-11-29
Federicoli
Nees Posted at 2016-11-30 11:09
Hmm, perhaps we had a bit of misunderstanding?  I had control over my drone, and had a live feed of the camera view on my phone (hence able to frame my shots).  However, some (not all) of the videos I had captured did not show up in the SD card.
2016-11-29
Hi, did you use the original SD card?  What about the photos?
Please save your video file first, then format the SD card and record some videos again.
Please let me know the videos you lost are most recent ones or earlier ones.
2016-11-30
4wd
Flight distance : 241706 ft
When recording video always give it a minute or so to clear buffered data and close the file - stop recording well before you shut off.
This might explain missing files if you shut down 2 or 3 times.
2016-11-30
Federicoli
DJI Mindy Posted at 2016-11-30 17:12
Please save your video file first, th ...
Thanks for the help Mindy.  I did not take may photos that day, but I did capture other videos.  The ones that were lost are not the most recent ones - I believe they are the first few (maybe 2 out of the first 3 videos).   I will try to formate the card and see what happens when I get home tonight.
2016-11-30
Federicoli
4wd Posted at 2016-11-30 22:20
When recording video always give it a minute or so to clear buffered data and close the file - stop  ...
Thanks a lot for the input! Is this something you've experienced before?
2016-11-30
Federicoli Posted at 2016-12-1 07:45
Thanks for the help Mindy.  I did not take may photos that day, but I did capture other videos.  T ...
Thanks for your cooperation. Please keep us posted.
2016-11-30
Albatross911
Flight distance : 1708084 ft
I had a similar issue earlier as posted on this thread. basically it did not save any video files on my SD card but I got the downstream 720p version on my phone.
http://forum.dji.com/thread-72841-1-1.html
2016-11-30
Federicoli
Albatross911 Posted at 2016-12-1 14:54
I had a similar issue earlier as posted on this thread. basically it did not save any video files on ...
Unfortunately my DJI app ran out of cache and I didn't turn on the option that allows the app to automatically delete older cached files
2016-11-30
Federicoli
DJI Mindy Posted at 2016-12-1 12:21
Hi Mindy, I tried the following things
1) Re-booted my Mavic, shot a few videos, turned it off and plugged in the SD card
2) Formatted the SD card
3) Used a file recovery tool
Unfortunately, none of these worked..
It seems like some others have faced the same problems before.  Any insights into why it happened and how we can avoid them in the future?
2016-11-30
Federicoli Posted at 2016-12-1 15:55
1) Re-booted my Mavic, shot a few videos, turned it off an ...
Sorry for the late reply.
Do you mean after formating SD card you will still lose some videos?
2016-12-4
usercc234eca6b
Flight distance : 27464 ft
I have two keys problems too.  The video I captured is not showing on the card.  But in properties I can see that the 16gb card is 50% full, eg 8gb of memory used, but no video files.  This would equate to the 10- 12 min flight time of video.  Secondly my mobile used to store the video files but this has stopped, therefore I cannot see the video  now.  This would be unacceptable on a commercial job.
2016-12-5
Albatross911
usercc234eca6b Posted at 2016-12-6 03:13
I had the same problem reported earlier and that time I had the 720p version on my phone to use. Didn't find any way to recover the lost files on the SD card.
Saving the 720p version is inconsistent. Just last Sunday I got 8 clips on the SD card but only 2 saved on my phone. Don't know the logic of that...
2016-12-5
MJS
DJI Mindy Posted at 2016-11-30 01:12
Mindy,
I'm having the same problem, with footage I shot today and that is not showing up on my card - no videos or photos. They are captured on my iPad that was used for controlling the Mavic. And the Micro SD card shows that it has 26Gb used when reviewed in Diskutility - so something is there, but it is not accesible in the Mac Finder...
2016-12-30
DJI-Ken
Flight distance : 1515312 ft
MJS Posted at 2016-12-30 14:19
Mindy,
Can you try a PC, it may be a setting on your Mac, it works fine on my Macbook.
If a PC doesn't work there's a slim possibility it may be the camera.
2016-12-30
MJS
DJI-Ken Posted at 2016-12-30 14:25
Ken,
I found the files using a utility called Disk Drill. So they were there but not accesible prior to using Disk Drill
2016-12-30
DJI-Ken
MJS Posted at 2016-12-30 22:20
Ken,
I see, good to hear.Thanks for posting, I wouldn't think the camera would have a recording issue.
2016-12-30
fans14b16605
Japan
Ken,
Hey what exactly did you do in Disk Drill? because ive had exactly the same problem but so far in disk drill its just found all my files i had previously deleted.
2017-4-20
Ecraft
Flight distance : 41332 ft
New Zealand
Albatross911 Posted at 2016-12-5 19:43
HI there, did you ever manage to recover the lost files at full resolution? i am having the sam problem.
I was glad to recover the lost files in the dji app cache but it is really not the same in post processing at only 720p.
thankyou.
2017-10-17
DJI Thor
Flight distance : 13602 ft
Ecraft Posted at 2017-10-17 23:29
thankyou.
I had replied your original post, please help to confirm.
2017-10-18
alaska42
Flight distance : 3254314 ft
I have had the problem before as well. Did you skip sequences on the card? I was missing an important sequence, but the others were on the card. So, I have DJI_185.mp4 and DJI_187.mp4, but not DJI_186.mp4.
2017-10-18
Tertius Jordaan
South Africa
Hi All
When i record footage on my SD card it all disappears when i restart the drone for the next flight. E.g Recorder 4 clips and when flying again it will erase the previous session's clips one by one as i record new clips until the current session's clips are the only ones's on SD card. Have lost such great foootage over time and only realize now what happens. Anyone experienced the same?.
2017-11-3
ZOID
Flight distance : 15246 ft
fans14b16605 Posted at 2017-4-20 06:55
Did you actually manage to recover the files in Disk Drill?
2017-12-14
ZOID
I found them using Disk Inventory X.    They were in the trash!! In the original Folder.  NOTE TO ALL.  Dont format the cards on your computer.  Always format them in the Mavic....   Lesson learned.  No harm done luckily.
2017-12-14
daqyvuvabi
You can try an SD card recovery software[/url] to give a try. Just connect the SD card to the computer and launch the data recovery software to scan. It supports to preview the lost mp4 video in the software, you can play it and check whether the videos are exactly you need. The last but important thing is to save the video to the computer but not back to SD card.
Try this r-datarecovery.com and good lucks.
2018-11-22
