Cannot update to 1.02.0602 from 1.02.0503 using DJI Assistant 2 o...
817 4 2016-11-30
tundrwd
I'm having problems updating my new P4 to the latest firmware using DJI Assistant 2 (v 1.07).
When I first went into the app, it seemed to "automatically" go into updating to 1.02.0503 (don't know if I had some mouse/keystroke buffered up, but I didn't even see the firmware list screen, just went into updating).
Updated to 1.02.0503 fine.
Now, when I try to update to 1.02.0602, the download went ok, but when trying to send the file to the P4, it waits for a minute or two at 0%, then I get a "Update Failed", and a "Note: Restart Phantom 4 before updating the firmware".  Attempting a retry results in the same thing.
I've powered down, and then repowered the P4 several times, restarted the Mac, and the Assistant app, nothing seems to work, and I keep getting the same error/message.
Should I remove the downloaded firmware (location?), and allow it to be downloaded again, and re-attempt?
2016-11-30
tundrwd
I will add that I've just attempted with an MS Surface Pro 4 (Win10), installed Assistant 2 on it, and attempted firmware update.  It was successful with this combination.
The Mac app (or the download file itself) has some issue.  I can definitely say that the Mac app is very "un-Mac like".  When running, does not display in the Dock when running, and there is NO menu displayed.  Cannot use CMD-Q to quit the app, must click on the Window close button, and then will get the confirmation if I want to quit the app.
2016-11-30
DJI-Ken
Flight distance : 1515312 ft
I am sorry about that, I'm glad you were able to get it updated.
You can also update through the GO app and that's probably the quickest and easiest way.
2016-11-30
tundrwd
DJI-Ken Posted at 2016-11-30 09:46
You can also update through the GO  ...
Unless I'm doing it wrong - the Go App (V4) doesn't show that there's an update available.
2016-11-30
DJI-Ken
tundrwd Posted at 2016-11-30 10:54
The latest firmware is 1.2.602.
In the General Settings, scroll down to About and it will list the firmware the aircraft is on.
https://dl.djicdn.com/downloads/ ... tes_en_20161108.pdf
2016-11-30
