Gary Mac
Flight distance : 741683 ft
1) I would expect the same. I'm going to be pretty critical of my horizon being level as it is a pet-peave of mine as a photographer. I may use a situation like this to actually adjust my roll gimbal to make it level. We'll see, I'm still a "waiter", so I don't have my drone in my hands yet.
2) You have two things going on here: First, I don't think the horizon is "level, at least not to my liking. It looks slanted down on the right. Not much, but not level. Second, lens distortion will ALWAYS cause things to slant that are off-center of the frame. Note the taller building in the background on the left. It actually tilts the opposite direction (toward the left). The appearance of the building in the foreground to be slightly tilted to the right comes from it being slightly off-center and is exacerbated by the horizon being slightly tilted to the right. It is also being filmed at a slight off-set to the natural lines on the building which don't help.
So, if you manually adjust your horizon to look level while flying, square-up and photograph a building dead-center of the frame and SQAURE to the building itself, it should look perfectly straight.
Hope this makes sense!
Gary
