Phantom 3 standard, black dot motors feel snappier -IS THIS NORMAL?
Gerardo Rejec
Flight distance : 120141 ft
lIKE THE TITLE SAYS, THE TWO BLACK FOTS MOTORS FEELS SNAPPIER WHEN I TURN THEM BY HAND, NO FRICTION, UT I CAN FEEL THEIR MAGNETS AS IF THEY WERE STRONGER.  DRONE FLIES PERFECTLY,  BUT THIS IS PERHAPS THESE TWO MOTORS  ARE OPPOSED TO EACHOTHERS SO ANY DIFFERENCE IN TORQUE GETS COMPENSATED BY THE ONE AT THE OTHER END. BUT STILL, I WONDER WHY THESE TWO FEEL SNAPPIER. ? PLEASE HELP,, DOES YOURS FEEL  THE SAME?
2016-11-30
WilliamM
Flight distance : 904364 ft
First turn OFF the CAPS. Now are your turning the props in the same direction of spin? One set turns CW and the other set CCW.
2016-11-30
Gerardo Rejec
WilliamM Posted at 2016-11-30 16:23
First turn OFF the CAPS. Now are your turning the props in the same direction of spin? One set turns ...
Regardless of which way I turn them, the two motors with black dots feel definitely as if their magnets were stronger. This is something I always noticed from day one. They do not overheat, and temperature has always been pretty much the same for all 4 motors after each flight.
2016-11-30
Aardvark
Flight distance : 384432 ft
Gerardo Rejec Posted at 2016-11-30 21:35
Regardless of which way I turn them, the two motors with black dots feel definitely as if their ma ...
If all is working well then they are fine.
2016-11-30
Betamace
Flight distance : 2133 ft
Gerardo Rejec Posted at 2016-12-1 05:35
It makes no difference, the motor speed is set by the respective ESC.
Torque factors in more than motor rpm on the CW turning motors.
I'm right handed and turning door knobs clockwise is always easier to me.
2016-11-30
Gerardo Rejec
Thanks,, I am still concerned a little bit even though after 72 flights never had a problem.. but I do wonder why the magnetism in these two is stronger.... quality control fail?  that would make sense since they are soo damn cheap to start with
2016-11-30
Aardvark
Gerardo Rejec Posted at 2016-11-30 23:03
Thanks,, I am still concerned a little bit even though after 72 flights never had a problem.. but I  ...
They may have been manufactured in different factories, perhaps different production methods. I would say if you've got 72 flights under your belt then nothing to worry about. If it does fail under warranty then I would be 99.99% certain that DJI would repair free.
2016-11-30
Gerardo Rejec
Aardvark Posted at 2016-11-30 18:08
They may have been manufactured in different factories, perhaps different production methods. I wo ...
Thanks... I'll just keep flying then
2016-11-30
