Akku Phantom 4 pro
1090 5 2016-11-30
indigooo
Flight distance : 178602 ft
Is there a differenz between  Phantom 4 pro batteries and the normal Phantom 4 ?
Are these batteries kompatible ?
Thanks for info
2016-11-30
Aardvark
Flight distance : 384432 ft
The batteries can be used on either aircraft, the newer battery has a slightly higher capacity.
2016-11-30
Labroides
Flight distance : 9991457 ft
Original P4 battery:  Capacity   5350 mAh
P4pro battery:  Capacity   5870 mAh
Slightly bigger capacity and they are compatible.
You can use both in either drone.
2016-11-30
indigooo
Labroides Posted at 2016-11-30 23:13
soo fast ....thanks
is there any other argue against ...because P4 batteries are allmost half price
2016-11-30
Labroides
indigooo Posted at 2016-12-1 09:29
soo fast ....thanks
is there any other argue against ...because P4 batteries are allmost half p ...
Slightly less flying time.
But if you want cheap batteries for slightly shorter flights - no problem.
2016-11-30
hallmark007
Flight distance : 10017858 ft
Hungary
indigooo Posted at 2016-11-30 23:29
soo fast ....thanks
Half the price where?
2016-11-30
