A3 and LB2 RC Calibration error
720 6 2016-12-1
amana3
India
Hi folks!
I am trying to calibrate the RC of LB2 on my A3, over the DJI Go App. But the damn thing fails to calibrate every time. Any help from anyone who has faced a similar problem? Or is it just how the LB2 is supposed to be??
2016-12-1
BrooklynDronesN
Flight distance : 1340610 ft
Same here. Just upgraded. Did you find a solution?
2016-12-15
SkySight Aerial
Flight distance : 2617713 ft
You need to downgrade the firmware and reinstall and then input all your settings again in Assistant.
DO NOT calibrate the RC in assistant (you don't need to) or you will get the error message again. Just check for 100% travel of the sticks.
2016-12-15
BrooklynDronesN
SkySight Aerial Posted at 2016-12-16 01:59
That was a huge help! Thanks.
2016-12-16
SkySight Aerial
You're welcome.
2016-12-16
SkySight Aerial
So I got the calibration error message again today and could not clear it either by calibration in the Go App or assistant 2 1.6.
So here is the work around.
Downgrade both Air unit and ground unit to the previous version.
You will need to relink the air and ground units.
The stick calibration error will still show (it did in mine) but you can then successfully calibrate the RC using the Assistant 2 and the error message disappears.
Upgrade the ground unit and the calibration error message has gone and the calibration appears to  have stayed correct.
Upgrade the Air unit rebind and you should be OK.
Just check your RC settings and if you are using a slave controller you will need to relink it to the Master.
2016-12-16
SkySight Aerial
2016-12-16
