DJI Mavic 4k Aliasing/Moire
7228 12 2016-12-1
braddahjosh808
Flight distance : 1868376 ft
My videos are showing really bad aliasing/moire in 4k/30fps and 2k/24fps. Is there something wrong with my settings or camera? I have sharpness set to -1
2016-12-1
C.Birch
Flight distance : 56365 ft
It looks fine to me coming from a camera that's so small, it's never going to be to the levels of the P4 and that, but on a side note you are being a bit silly flying when you did in my personal view, it looks very windy and rain looks to be due any sec and i can not see the drone and water getting along.
2016-12-1
braddahjosh808
C.Birch Posted at 2016-12-1 11:00
It looks fine to me coming from a camera that's so small, it's never going to be to the levels of th ...
The video looks really annoying and terrible to watch. It's worse on other videos that I have recorded.
Also, the Mavic handles really well in this wind condition and i've only brought it up for less than a minute to test the video settings.
2016-12-1
4wd
Flight distance : 545817 ft
It looks quite good here too, it does seem to depend on how you are viewing it.
You might try sharpening on -2 and contrast saturation both -1 if using default none setting.
If you can view it on a 4K TV you might be surprised how artefacts have magically disappeared.
2016-12-1
braddahjosh808
4wd Posted at 2016-12-1 11:28
You might try sharpe ...
I am viewing it on my MacBook pro which isn't 4k. Should I try downsampling the video to 1080p or recording at 1080 to see if that makes a difference?
2016-12-1
Nees
Flight distance : 80991 ft
Belgium
I see nothing wrong. Must be your display and the resolution you are looking at.
2016-12-1
braddahjosh808
I have concluded that it very well is my screen because i don't see it when I view it on my iPhone 7. That is very good to know. I thought that I was doing something wrong.
2016-12-1
look_alive
Yes. It is very apparent. I can easily see a fair amount of aliasing and moire in the rooftops of every building in your video. This is a common problem with cameras of this size and type, and a very common complaint of the Mavic, especially.
2016-12-1
MikeQView
thats strange because on my laptop its really good, exceptionally clear of Allaising ????   so it can be only one of two things,   1) different screens and processing produce different results .   or   2) the eye of the beholder see's it differently ?????
2016-12-1
JohnnieYaz
Flight distance : 5137874 ft
I get this too.. I'm not happy at all. Looking for a fix.
2017-1-16
DRONE-flies-YOU
Flight distance : 1450594 ft
braddahjosh808 Posted at 2016-12-1 13:26
It sure flies nice in a hurricane - good to know!
Yep, watch 4k on a 4k screen.  Otherwise it's like stuffing 16 clowns in a VW Bug.
2017-1-16
boostedford
Flight distance : 144478 ft
looks fine to me
2017-1-19
daivatam
Flight distance : 473389 ft
Romania
yes the mavic has bad moire only thing you could do is decreasing sharpness...and never film below 2.5 k....
2017-1-19
