fans913aa526
Hello,
You can use any good quality USB charger. The output voltage would be regulated 5V. The input current (Amperes) to the RC controller is determined by the state of charge of the battery. There is a very simple and inexpensive device that you simply connect between the charger and the power cable to the RC controller. This way you can monitor both voltage and current. You will see the current reducing as the battery charges. Hope this Helps. |
