Compass calibration fails (metal in body?)
2298 16 2016-12-2
Ledg
Flight distance : 780958 ft
i have recieved my mavic pro today. But i can not get the compass to calibrate. i am stood in the middle of my garden doing it as shown on lots of videos and in the manual. i leave the controller and phone away from me on the ground, but it fails every time.  The slight problem i may have is if titanium affects it as i have a plate in my collar bone. id get my girlfriend to try but see has one in her arm (yes we are accident prone lol).  Does anyone know if my plate could be a problem? Or is there something wrong with my mavic?
2016-12-2
jkvenuti64
Flight distance : 88543 ft
no need for the calibration unless you have issues.  Mine said normal when I first flew, therefore if it aint broke...don't mess with it.
2016-12-2
MavicNewbie
Flight distance : 668015 ft
Please note when you rotate your drone vertically, you need point the drone nose (front) downward.
I got calibration error when I point it upward -- I think Dji should make it clear in the app calibration intro.
2016-12-2
chuck9
I don't think that titanium is magnetic, that should not have an effect, other than being cool.
2016-12-2
Ledg
jkvenuti64 Posted at 2016-12-2 21:28
no need for the calibration unless you have issues.  Mine said normal when I first flew, therefore i ...
mines telling me to calibrate the compass, i don't dare take it off incase it just drifts and crashes because of the compass error
2016-12-2
Visualkaos
Flight distance : 755988 ft
sometimes you have to go more than 360 degrees spin before it acknowledges the calibration.  I have seen some in the past not go far enough and the calibration would fail.
2016-12-2
rick39
Flight distance : 164354 ft
You're not wearing a watch, or worse still a smart watch?
2016-12-2
Ledg
rick39 Posted at 2016-12-2 22:42
No. its working now. no idea what i did differently but it failed then i retried and its started working. guess it calibrated. not standing near your phone you can't read what it says. but the light didn't flash red readily like it had when it failed.  I say leave it well alone now till it makes me do it again.
2016-12-2
AYA74
Flight distance : 2002713 ft
You can read through this post. A few other users including me had the same problem. I got mine eventually fixed by sending it back to DJI. It is a problem of faulty compass board.
http://forum.dji.com/forum.php?mod=viewthread&tid=72487&page=2&mobile=2#pid579621
2016-12-2
AYA74
One more thing. To identify if the same is same as mine, you need to check the settings of the compass sensors and see if one of the two compasses moves to the green zone but the other one stays in red.
2016-12-2
Ledg
AYA74 Posted at 2016-12-3 04:45
One more thing. To identify if the same is same as mine, you need to check the settings of the compa ...
It started working. Both compasses are in the green zone now, but when in sports mode and sometimes in normal mode when going full throttle forward it comes up with a compass error, as soon as i let go of the stick the error goes every time. I'm afraid to do another compass calibration as it took so long to get it to work the first time. Seems to fly alright, slight drift when its dark in my yard (not sure if thats normal, only had about 10 sats
2016-12-3
canadianairborn
Ledg Posted at 2016-12-4 03:38
It started working. Both compasses are in the green zone now, but when in sports mode and sometime ...
I think low light drifting is due to the position sensor not being able to see the ground well enough. Next time it starts to drift, try disabling the downward position sensor to see if it corrects the problem. If not, could be a compass issue.
2016-12-3
Ledg
it Lost gps today with after having 17 sats. luckly i noticed and managed to fly it a bit further in atti and it regained satellite connection and continued to fly home. Guessing this could also be due to compass calibration. i need to go find a nice big grass field to do a recalibration in the middle off.
2016-12-4
Ledg Posted at 2016-12-4 23:57
After the re-calibration, please test it and let us know the results.
If still have lost GPS signal issue, please sync your flight records. I'll help to check it.
2016-12-4
djiuser_64FAenFSKFnk
New Zealand
Hello I have calibration problem because of long titanium rod n lower leg can I use any thing to shield it???please
2019-1-19
HedgeTrimmer
Titanium is barely magnetic.  Might be your plate has other metals besides Titanium in it, that are magnetic.
2019-1-19
HedgeTrimmer
You could use one of Free (or nearly Free) Android or iPhone Apps to see if your plate (for some reason) is causing magnetic interference, thus effecting Earth's magnetic field.
2019-1-19
