This is a brand new phantom 4 I just got yesterday set it all up and it reads this error along with not reading the onboard sd card and zero transmission signal any help?
Geebax Posted at 2016-12-3 16:55
Take it back ASAP as a dead on arrival.
Yea I was pretty disappointed I called a couple different stores today since the seller from amazon was closed today and they all said the same thing they said it's very odd it won't even read the micro sd card it came with. They said amazon has a no questions asked 14 day return policy and the seller probably has a agreement with dji where they will have to take it back I mean it's fresh out of the box
May I know what mobile device you are using?
Please try to restart aircraft, or change another mobile device then check again.
Have you tried to calibrate IMU and gimbal, format SD card or change another SD card?
Back when I got my Phantom 3 Pro and tried to do a firmware upgrade it would always fail no matter what I tried.
Then I saw that the little connector on the bottom of it was disconnected, I connected it manually and it worked since then.
