SkySight Aerial
Flight distance : 3312018 ft
I know this is a waste of time but I thought I would put it out there as I am sure this won't be an isolated incident. Seems DJI have more bugs than I'm a Celebrity!!
First of all let me say that the last time I flew this rig I had no issues and have not touched any of my settings since.
So I'm out in the field with a client today, pre-flight checks all done and start up sequence entered and I get a message that a stick calibration is required.
I switch off the aircraft and complete the calibration process, reboot the transmitter, switch on the aircraft and the message is still there. So I go through the process again and again and again and..................................................... Finally the message goes away and I get the safe to fly GPS notification with 20 satellites. Home point is confirmed and I take off.
It is my usual practice to hover at two meteres and check the control inputs before comencing the operation. So I yaw the air craft, fine, left, fine, right, fine, forward, fine, but when I try to move rear wards there is absolutely nothing and the aircraft in GPS mode is now drifting in the wind with no GPS hold. I manage to land and disarm and tried stick calibration again - same result and the light is fading. My client is getting the hump so I have to resort to my backup aircraft. Thankfully that was fine and I managed to complete the operation and relieve some of my embarassment.
When I got home I tried calibrating the sticks within assistant 2 with no joy so I took the following action.
Down graded LB2 and A3 firmware which wiped all my settings, reinstalled both updates and completed the setup parameters, bench tested and all was operating correctly again.
I have now modified my operations manual to include a bench test of my S1000 before leaving home. That should not be necessary, but it will save any future embarrassment.
The rig that failed today was:
S1000+
Lightbridge 2
A3
Z15 GH4
My back up which flew faultlessly out of the box..........................Yu***c H9*0 for GH4.
