justin.bregar
Flight distance : 19035 ft
I got my new controller bound to my Phantom 2 w/ H3-3D, but I don't think the gimbal tilt control wheel is working right. I've calibrated both using the hardware calibration instructions (hold both sticks up, turn on, etc...) and using RC Assistant. I've also calibrated X1 in PT2.
When you pull the wheel down, the gimbal tilts to straight down. When you let go, it returns to 45 degrees. Push up on the wheel, and it goes to straight ahead. Let go, back to 45 degrees. Having to hold the wheel in place to keep the gimbal pointed at a specific angle is really clumsy and I don't think this is the way it should work, right?
How do I fix this? Running all latest firmware.
