Phantom 4 Pro HDMI out
18042 38 2016-12-5
Eltee
Hello DJI, I got my P4P today. According to the specs there would be a HDMI out on the controller. To my suprise there isn't
Does the existing HDMI out module works on the P4P controller?
2016-12-5
WeAreRebellion
THe HDMI out was only on the P4P+ controller if I remember correctly.
2016-12-5
Phoenixaerial
WeAreRebellion Posted at 2016-12-5 17:24
Ju .......... ............ ..........
2016-12-5
Phoenixaerial
Here is says HDMI
2016-12-5
marctronixx
Flight distance : 210118 ft
yes it has both versions of the RC: the GL300E that ships with the p4p+ HAS hdmi
the GL300F has USB only.
since you have the p4pro non plus you only have the GL300F.
that is my interpretation..
2016-12-5
DJI Natalia
Flight distance : 318 ft
Phoenixaerial Posted at 2016-12-6 09:51
Just got me P4P and no HDMI output even though it says it on the web site??
The HDMI out is available for the P4P+ remote.
While you can install the HDMI module into P4P remote if needed.
2016-12-6
WeAreRebellion
It says the GL300E has HDMI. You have the GL300F remote.
2016-12-6
Phoenixaerial
DJI Natalia Posted at 2016-12-6 01:19
I put my module one ( after market ) from my P3P into the P4P and it doesn't work.
Even pulled the one off my 2 inspires and nothing... Thoughts??
2016-12-6
Phoenixaerial
WeAreRebellion Posted at 2016-12-6 09:03
E or F it looks the same after a few drinks.. lol
2016-12-6
DJI Natalia
Phoenixaerial Posted at 2016-12-7 07:54
We've reported this case and engineers are working on it now, sorry for the inconvenience caused.
2016-12-6
DRONE-flies-YOU
Flight distance : 1450594 ft
Shows that it excludes display upon ordering and confirming your order:
2016-12-6
volare film
Flight distance : 251499 ft
DJI Natalia Posted at 2016-12-7 05:04
It's the same for me.
It doesn't work.
Please DJI engineers upgrade the RC firmware.
2016-12-7
DJI Natalia
volare film Posted at 2016-12-7 17:15
It doesn't work.
Our engineers are working on it now and the firmware will be released soon, thanks for your support!
2016-12-7
ulisse
DJI Natalia Posted at 2016-12-7 10:22
Thanks Natalia!
2016-12-7
mikesher.live
Flight distance : 123045 ft
I installed a brand new HDMI module into my P4P.  It didn't work either.. wouldn't connect to the P4P.   Glad the engineers are looking at it.  In the meantime, I bought an Nvidia Shield for the HDMI output.
2016-12-7
DJI-Jamie
Flight distance : 112405 ft
A firmware update is needed for the P4P RC in order to make the two compatible. The update will be coming out soon.
2016-12-7
Chazzm
Oh wow I certainly hope it's real soon, I fly with goggles all the time, I have the RC memorized, and I can see my hud which shows me battery level, height,distance and altitude, camera settings, that's all I pretty much meet, so please please please roll out the firmware up date, I need it soon!!! Think possibly it will be out by this Monday or Tuesday?
2016-12-9
Chazzm
If you ask me(which no one did) both of these RC should have the same output/input modules! I for one would like to have the HDMI, and micro SDF card slot etc as well, seems almost like those of us who didn't get the 300+ built in screen have gotten cheated bait! If the engineers can make the phantom 4/3 HDMI modules work I'd be happy, but we would all be happier with the same module the other RC has !!!
2016-12-9
Gobopolice
Flight distance : 926745 ft
OK HDMI working now for me after the update, But there is a problem in the APP "HD" page  if you disable the HDMI slider it DISCONNECTS everything !!!! Be Warned !!
You can disable the OSD output OK but Dont try and Disable the HDMI in Flight !!!   BUG exists still..
2016-12-9
Gobopolice
OK update on HDMI module, It works as I mentioned but when you go into the goapp to HD page and slide the green slider to off "transmit to hdmi"  the screen on go app freezes and says disconnected, But in fact I still had control of the craft ? and the HDMI monitor next to me was still "live" with telemetry, so it didnt turn off the feed to the monitor at all but turned off the feed to the go app !
The telemetry on Go app was also still live but not the video feed, I brought up the battery information screen (linked to my C1) and that worked, So its got to be a bug freezing the go apps live feed.
anyone else experience this.
2016-12-10
nevoeiro1974
Portugal
marctronixx Posted at 2016-12-5 18:07
I agree with your interpretation. Those are the specs for both models !
2017-7-7
fansd6731455
Hello
I have installed the HDMI Module on my P4 pro remote GL300F and the hdmi does not work  with the latest firmware on both rc and drone
help !!!!!!!!!!!!!!!!!!!!!!!!!
2017-11-9
fans0c514330
fansd6731455 Posted at 2017-11-9 00:52
Hello
I just received the new PH4 Pro Obsidian which has the GL300F Remote Controller and only has 1 standard size USB and 1 Mini USB. Has DJI gotten there firmware working properly yet?
2017-12-1
djiuser_eBiSoDG
Flight distance : 7365 ft
Hello
Did you get your p4p going ?   I put a hdmi module in my p4p controller this weekend now it's  won't work. I have tried everything. Nothing worked.
2017-12-2
Bashy
Flight distance : 2354357 ft
I added a new HDMI module to my P4P remote the other day and it works, well, the USB works fine, cannot try the HDMI yet as i ordered the HDMI midi instead of mini connector :/
I am sure it should work though, i have seen many YT videos where folks have it work with goggles etc...|
Make sure the  ribbon connectors are fully in
2017-12-2
KedDK
Flight distance : 1133038 ft
Denmark
djiuser_eBiSoDG Posted at 2017-12-2 19:23
It is my understanding that all that need to be done is a re-install/refresh of the current FW in order to get the correct module installed.
But O.C. chances are that the current FW can have issues ... :-/
2017-12-3
davawt
Flight distance : 4885 ft
KedDK Posted at 2017-12-3 04:07
Hi there,
I installed a HDMI module just a few weeks ago and everything works perfect, (Goggles)
Once installed did you do the C1 and C2 button checks on the RC to see if you have done it right?
You should get a beep when you press either one of those keys on the bottom of the RC.
Once they work then you know the connections are right, then turn on as usual RC / AC.
Update anything you are asked to do, connect a mobile or tablet to the RC using USB. I used iPad 4 mini.
Then goto the HDMI area on the GO 4 app menu and select Output options you want.
Then connect to a HDMI unit ( Goggles ) and away you go.
Try the above step by step, there is a very good video on youtube from DJI that helps a lot.
good luck, bye
davawt
2017-12-3
KedDK
Denmark
davawt Posted at 2017-12-3 07:10
Hi there,
Thank you, but i think you replied the wrong post, i have no problems with HDMI other than DJi have some bad habits with settings removal, ex. the HDMI overlay on/off toggle.
2017-12-3
davawt
KedDK Posted at 2017-12-3 07:17
Sorry KedDK,
I should have gone to specsavers, UK. it's a weekend thing, I will need to wake up and read stuff before replying.
Any way enjoy your flying, these DJI drones are great. bye
davawt
2017-12-3
davawt
Hi there,
Also read Bushy's post about connections,
good luck, bye
davawt
2017-12-3
Dockater
Flight distance : 139649 ft
I fitted the HDMI module to my p4p controller without issue. It is not something however for clumsy fingers. Check on youTube, there are several videos, the ribbon cable connectors can be a challenge. Dont forget the FW update.
2017-12-3
djiuser_eBiSoDG
I havent got my p4p working yet after module upgrade. Of those who have don't it successfully what is your firmware version found in the "about" section in go4 app??
2017-12-4
djiuser_eBiSoDG
I meant those who have done it successfully
2017-12-4
Sparky_Iosif
Flight distance : 7346 ft
Philippines
Can I use the HDMI video output to a Capture card for OBS?
2018-5-6
clint0
Flight distance : 131624 ft
I got my HDMI module installed in the RC, but now I don't have any power-up beeps from the remote.  HDMI works perfectly.  It also doesn't seem like the USB is pushing power to the tablet, either.  I've asked around but haven't found any answers.  I'm reluctant to send it in to DJI.  Firmware is 1.04.01.00.
2020-12-24
djiuser_MSq8dZOKAzaY
Hi I have a Phantom 4 pro v2 and when I bought it I was told that they were working on a hdmi out module and it should be out soon, has dji sorted out this problem now? It has been several years since the problem was pointed out but we are still waiting on it being sorted out, I contacted dji recently and was told that they are still working on the problem and it should be sorted out soon how long is "soon" in dji's view? It seams all they want to do is take your money then ignore you from then on, I have owned this model for over 2 years and it has not been in the air yet as I do not want to fly it with a screen I cannot see outside I know I should have returned it within the warranty period but I kept believing what dji was saying about them working on it I doubt they had anyone working on it except for the poor call center workers who had to keep making up excuses to owner's, I accept I will see a phantom Pro 5 before I see a hdmi for the Php 4 v2.
Regards Poppy Ann.
2021-8-22
Geebax
djiuser_MSq8dZOKAzaY Posted at 8-22 23:34
Regards Poppy Ann.
You wont see a Phantom 5, that line of aircraft has been dropped. And no, you wont see a HDMI conversion now, DJI do not intend to keep supporting the Phantom series.
2021-8-23
Poppy Ann
Geebax Posted at 8-23 16:08
I agree with you that i will never see a hdmi out before they stop servicing it I think this is a terrible way of treating customers i belive that they had no intention of ever "working" on a way to get a hdmi out on the phantom-4-pro-v2 from the first day it went on sale.
I still believe that dji makes the best drones on the market but they have the worse customer service i have ever come across.
2021-12-16
djiuser_zl5r1eK77AF6
So if i have the Phantom 4 Pro V1 with the GL300F controller cant I just swap the Module for a GL300E that has the HDMI ports?  If I can what programming needs to be done if any?Or i could just buy a used in good condition GL300E and link it to the AC and have the display to boot.
Thanks
2023-11-14
