Balancing Propellers
635 4 2016-12-7
DotheMath
Flight distance : 2113 ft
Good Morning! A newbie question for you all! I recently noticed when I started the motors on my last flight that the arms flexed a bit on motor start up. I've purchased a balancer and am currenlty awaiting its arrival. So... What are some of the best practices for balancing props? Any tips or tricks? What materials do you use to balance?
2016-12-7
Labroides
Flight distance : 9991457 ft
It's really not necessary if you are using DJI props.
2016-12-7
fansa84fe8a4
Flight distance : 3 ft
Mine weren't bad, just a little off.  Bit of smoothing of the edges even them up.
However, what I found more disturbing is that some were bent, probably being pressed on too much while in the box.  When I put them on the P4 and spun them by hand, I could see one blade maybe 1/2 inch higher than the other.  I thought it would straighten in time flying, but every time I stopped, it was bowed up.  I finally held it and re-bent it.  Had I tried to balance that one first without straightening, that might have been a boo-boo.
2016-12-7
RedHotPoker
Flight distance : 165105 ft
Balancing can be done by lightly sanding the emblem or arrow near the hub. Tiny bits of scotch tape. Some here utilize clear nail polish.
Use your imagination. ;-) all though that won't balance much more than your immediate thoughts. Haha
RedHotPoker
2016-12-7
Ange1walk
Flight distance : 30305 ft
Austria
Well, you don't really need re-balancing (if it isn't too bad)
And also, the arms flexing is normal, it's designed to flex. If it were rock solid and did not move a millimeter, Aerodynamics in flight could rip them apart
2016-12-7
