potthoff
Flight distance : 982579 ft
jdh,
There isn't much of a use anymore to get a 333 for sUAS. Getting the 333 was previously the only way to fly sUAS commercially. If you still wanted to get a sUAS, you would have to get a private piolet license (Expensive but you get to fly planes) and probably a lawyer to help fill out your application. Honestly, I think the commercial community would give a lot more respect to the manned airplanes if they still required a private license.
For s107, all you need is to pass that generally knowledge test and a background check. It's a pretty straight forward test but you need to know the material. I recommend taking that practice test from the FAA. I also really like an app on the android play store called "Prepware Remote Pilot". It's $5 but about %50 of the questions on the Knowlege test were from that app. It's a lot cheaper than retaking the test. Definitely, go over the topics that QiiFlight said.
Lastly, just from my experience in the commercial field. You will get much more business on drone for hire jobs if you decide to go with 333, or get an s107 using privates license. For many jobs, You will also be required to get $1 million sUAS insurance. It gets pretty pricey unfortunately.
Good Luck,
Josh |
