mk1
South Africa
Hi,
So today was around the 6th flight I had with my Phantom 3 Standard and the drone flew away.
Everything was normal. I turned on the drone, it had GPS signal, its home location was set and was in GPS fly mode.
I was about 40 meters up in the air when the drone just suddenly started flying away from me.
When it started flying away the app told me the signal is getting bad so I went up to higher ground and selected return to home which failed and then I lost singal to the drone.
I was not worried because when the Phantom looses connectivity with it's controller it would automatically return to home, as it is designed to do.
The drone never came back
I drove around with the controller in my hand and found the drone 385 meters from my home location, it landed safely and had no damage.
I have uploaded the log to log viewer:
http://www.phantomhelp.com/LogViewer/NGI8JAQTISCYIZAK3PZC/
Now please explain to my why the drone never returned to home when it lost connection with the controller as it is designed to do?
There is alot of "YAW" errors in the log, what does it mean?
In the log it mentions: Signal Lost. Aircraft Returning Home
It never went home, it went the opposite way!
If I look at the location on the log viewer map, it does have the correct direction and path the drone flew, but only up to a point. The location on the map is not correct, I found the drone about 100 meters further than displayed on the map.
I am now scared to fly my Phantom again because next time I might not be so lucky if it goes crazy again.
I am raising a ticket with DJI to check what went wrong.
I want to know what happened, is there something wrong with my Phantom?
Lucky I also recorded the flight and have the video evidence.
Very dissapointed DJI Phantom 3 owner
