Cetacean
Flight distance : 2528264 ft
Aloha fans477,
As you are learning, it is best to have more than a Gig of RAM available for flying. The recommendations are for 2 Gigs RAM at a minimum for the basic phone at purchase. But, if you can clean up your Note Edge and disable non-DJI GO related apps, it will help a lot. I cannot find the Note Edge in any suggested listing. I can find the Note (s) 3, 4, 5, & 8 and one S6 Edge. They are plenty and powerful enough (except the 8). But, what are the power specs on your Note Edge at purchase?
It is not going to get any easier on your phone (or tablet) and at some point, the DJI GO app will stop working on it completely if it is not powerful enough. It is best to have a powerful tablet dedicated to flying. The most popular Android tablet is the nVidia Shield K1 (8" tablet) and it sells for only $200 but is very powerful. Probably why it is so popular!
One other thing you can try to see if you can get around this problem for now is change the setting on your Live Feed system from Auto to Custom. It is in the HD icon at the upper right of the flight screen. When you pick Custom, you will be able to see the signal strength of the 8 channels. Follow the legend and find the most stable green channel and pick it. Then look at the bandwidth slider and you will notice that it is one notch to the right of the lowest setting. Slide it to the left to the lowest setting. Then return to the flight screen and see if it makes a difference.
Hope this helps!
Aloha and Drone On! |
