Heavysledz
Flight distance : 819491 ft
QuanthonyTrang Posted at 2016-12-8 23:27
To force ATTI or lower GPS counts, place foil on the top of the mavic. Not sure where the GPS is located in the Mavic, but this is what p2/p3 used to do.
And make sure you set to HOVER for RTH. If by chance the mavic creates a false homepoint and the controller decides to wig out, the mavic may ascend to the roof and attempt to RTH.
GPS is in the tail of the drone. If you pop of the rear LED indicator cover, you will see it inside. It is the silver perforated module in the rear of the picture. You can see the lead wires for the antenna on the right hand side:
