Nees
Flight distance : 80991 ft
Belgium
When you look at the top, you see the battery bar. It is dynamically changing. The closes to you, the longer the green bar, the shorter the yellow and red bar. The further you go away from you, the point to return safe, changes more to the middle, longer yellow bar. Pretty easy to calculate concerning distance... But it will not take into account of windspeed. So always be safe and when very far away, bring it back closer before you need to and be on the limit of not making it, when there are strong headwinds that you didn't know. |
