Can the window size be adjusted in P2 Vision Assistant?
2764 10 2015-2-11
MelC
When using the P2 Vision Assistant to set up my P2 V+ V3, the text dialog windows in the app don't show all the text. The print is too large or the windows are too small to show all the text. I'n using W8.1 on a Lenovo laptop with a 17in screen. Screen resolution does not change the symptoms and the window size within the program cannot be adjusted.
Anyone else have this problem and is there a resolution for this problem?
Mel
2015-2-11
johnwarr.live
Flight distance : 6467 ft
Strange problem, mine is fine on my 17" laptop at 1920 x 1080.
2015-2-11
PanamonCreel
Mexico
What screen resolution are you running ?
2015-2-11
MelC
PanamonCreel Posted at 2015-2-12 03:55
1920 x 1080
2015-2-11
MelC
Hi, my screen resolution is 1920 x 1080.
2015-2-11
PanamonCreel
Mexico
MelC Posted at 2015-2-12 04:36
in that yes it seems strange,  also running WIN8.1 at the same resolution and it is just fine.
Do you run the assistant as a window on the Desktop or as Full Screen?
2015-2-11
MelC
PanamonCreel Posted at 2015-2-12 07:40
Do  ...
I run it as a window. When it opens there is no full window button. Minimize and close are the only two options.
2015-2-11
bjr981s
Flight distance : 139698 ft
MelC Posted at 2015-2-12 11:28
I run it as a window. When it opens there is no full window button. Minimize and close are the onl ...
Have a look at your default Font settings in Windows. The default font you have may be too big for the window.
2015-2-12
MelC
bjr981s Posted at 2015-2-12 17:00
Have a look at your default Font settings in Windows. The default font you have may be too big for ...
Duh, that was it!!!! I consider myself computer savvy too.
Thanks for the guidance.............Mel
2015-2-12
bjr981s
MelC Posted at 2015-2-13 02:17
Thanks for the guidance............. ...
No Problem, Glad your got it working.
Cheers
2015-2-12
olivierdamiron
I posted this on another segment of the forums but anyways, here is my two cents worth:
It is not a windows 8 problem, it is the application. It should automatically adjust to your resolution. I emailed DJI about this, they told me to try it on a different laptop. Great. That helps a lot.
A few other programs had that issue, such as Photoshop. They issued an update that fixed it. DJI needs to update the Assistant software but it seems it is not on their priority list. I was told to try different resolutions, the usual BS answer, and obviously that didn't work.
One should not have to change a machine's resolution to accommodate specific software when all the other programs work great. I am really pissed because it is the only app on my computer that is unusable. It turns out it is the one I need the most in the field. All they need to do is update the app but I guess the thousands of NAZA customers are of no importance since they launched the DJI Inspire. I was going to purchase one but I think I will hold back in light of their complete lack of concern for an issue that will affect anybody who buys a new laptop in 2015. Every laptop now has high resolution displays. Not a happy camper.
Harware: Lenovo Yoga 2 Pro
2015-2-26
