Upgrade issue...
1737 9 2016-12-9
JWC P4
Flight distance : 8176 ft
South Africa
I got my P4 Pro yesterday.  After firing up (same as my normal P4) the Go-app had a Firmware Upgrade notification.  I tapped on the notification which took me to the upgrade info page (the normal info - plug the USB into aitcraft, do not disconnect etc...)  There is no further "upgrade now" button... just a "dumb" page.  I then went to the Assistant 2 app on the PC.  After logging in it found the Phantom 4 Pro but displayed a message:  Cannot load Firmware list - please retry.  After a few retries and getting the same message I'm back to square one.
Any ideas / suggestions?
Regards
2016-12-9
DJI Natalia
Flight distance : 318 ft
May I know what mobile device you used to connect the remote? you have installed DJI GO 4 and tried to upgrade through APP, it failed, right? may I know any error message popping out?
Please try to restart the aircraft and try again with Assistant 2, you can reset it to factory default firstly and check again.Besides, please make sure the internet connection is great.
If still the same case, please post a screenshot here.
2016-12-9
JWC P4
South Africa
DJI Natalia Posted at 2016-12-10 08:41
Thanks!  I use two devices (same as with my Phantom 4) - A Samsung Note 5 and a Samsung Tab 4 S.  I do not think it is the device as I never had problems with them before....  I tried two internet connections.  !.  Wifi via a 2M line and 2. High speed LTE cell connection to Assistant 2  (as I did in the past with my normal P4).  Both failed - also after restarting the P4 Pro.  Same error msg:  "Cannot load Firmware list - Please retry".
I have flown the P4 Pro now for an hour without issues but still would like to do the firmware upgrade.
2016-12-10
DJI Natalia
JWC P4 Posted at 2016-12-10 20:25
You upgraded it via Samsung with DJI GO 4 installed, right?
We can try to change another IOS device to upgrade it again if convenient, which would make sense.
2016-12-10
JWC P4
South Africa
DJI Natalia Posted at 2016-12-10 15:08
Yep! Go-app 4.0 installed on both devices.  No go!  I have discovered that there is a brand new version of Assistant 2 for P4 P - released yesterday!  I installed that and could update the drone successfully.  It did not pick up the controller though.  Can you tell me the latest software version of the standard P4 Pro controller? (GL 300F).
2016-12-10
DJI Natalia
JWC P4 Posted at 2016-12-10 23:08
Glad to hear you upgraded the aircraft successfully.
The latest firmware for P4P remote is V1.3.0.0, you could check the details here: https://dl.djicdn.com/downloads/ ... ro+Release+Note.pdf
2016-12-10
JWC P4
South Africa
DJI Natalia Posted at 2016-12-10 19:28
The latest firmware for P4P remote is V1.3.0.0, you could check the details here: https://dl.djicdn.com/downloads/phantom_4_pro/Phantom+4+Pro+Release+Note.pdf
Thank you!
2016-12-10
smokey_truck
DJI Natalia Posted at 2016-12-10 12:28
If I using the P4P+, how do I use DJI Assistant 2, it is taking a while to download for upgrading firmware. I want to upgrade using SD card.
Smokey
2016-12-10
DJI-Jamie
Flight distance : 112405 ft
smokey_truck Posted at 2016-12-11 05:50
Smokey
Have you been able to connect to the Assistant 2 software before? If you still need to install the software, please do so while the unit is turned on and plugged in to ensure that the necessary drivers install.
2016-12-10
DJI Natalia
Smokey
In addition, here is the specific steps for upgrading aircraft with Assistant 2.
To upgrade P4P+ remote, please check the document: https://dl.djicdn.com/downloads/phantom_4_pro/How+to+Update+the+Remote+Controller+Firmware+of+Phantom+4+Pro+Plus.pdf
2016-12-10
