Aardvark
Flight distance : 384432 ft
Sky173 Posted at 2016-12-12 18:01
Alrighty... I spent last night trying to figure it out and I think I found the issue. My controller doesn't like V1.6.0. I downgraded the controller and the P4 to the previous firmware. Once I did that, the picture was perfect! I was so happy, but unfortunately I'm grounded because it's not 'up-to-date'. I left the controller at V1.5.80 and upgrade the P4 to the latest version and the picture was still perfect. Once I upgraded the controller to V1.6.0, the image problem came back.
I've been seeing people on the forums talk about a version V1.8.0 but I haven't see it yet...
I had assumed that you would be rolling back from V1.8 to V1.6 as you said you had all the latest upgrades. Now a number of people complained of video transmission problems after moving to V1.8, so the roll back was fix for some. If you can get picture perfect then that should be sufficient surely. After doing the rollback to V1.6 did you try resetting controller and re-linking to the aircraft ?
The P4 should be good on latest firmware.
Edit:- Perhas you need to consider one of the devices on DJIs supported list.
iOS Version v3.1.1.
Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v3.1.0.
Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
