Warning message
1213 6 2016-12-10
fans3593671f
Flight distance : 10425610 ft
Having a few problems since last dji go update. Getting a lot of warnings in regards to motor overload and gps errors. This is happening on both inspires, so it's not a aircraft problem. Anyone else experiencing these problems?
2016-12-10
Donnie Stugots
Flight distance : 3636782 ft
Motor overload one is fairly common , no worries on that .  Regarding the GPS  I would do a full calibration of IMU and compass and see if it clears up .
If that does not clear up the GPS problem , be specific on the challenge and we will put our collective minds together an help ya'll figure it out.
All the best to you and yours-
donnie
2016-12-10
DJI-Jamie
Flight distance : 112405 ft
Could you verify which Go app version you have and what mobile device do you use? Which firmware are you running on your Inspires? Could you happen to provide a screenshot of what you're experiencing?
2016-12-10
fans3593671f
All up to date
2016-12-12
fans3593671f
App 3.1.1
Aircraft 1.9.1.30
Remote 1.7.60
Camera 1.9.1.10+
iPad air2 iOS 10.1.1
2016-12-12
DJI-Jamie
fans3593671f Posted at 2016-12-12 19:44
App 3.1.1
Aircraft 1.9.1.30
Remote 1.7.60
Just to clarify, how far out would you be when you receive the GPS errors? What kind of areas are you flying in? Was the aircraft and camera firmware already up to date without issues prior to updating the app?
2016-12-12
fans3593671f
Nothing has changed apart from the djigo update. I have flown many times at a local flying field and never had a problem. I got the gps  error when the battery was at 50% or lower and the motor error from the start when I pushed it hard. Tried different batteries with same results. The gps error even happened at the beach over water. So no, no towers or metal anywhere near.  Should I add that I'm not new to this, so I know where and where not to fly.
2016-12-12
