Osmo pro camera facing ahead
752 4 2016-12-10
B1gfoot
Is there any way to keep the  X5 camera inline with the Osmo handle when you turn with the Osmo? Orientation lock or holding trigger button as discussed in other threads doesnt work.
The camera just wants to keep facing its original direction, making it next to useless to film and turn at the same time.
2016-12-10
Skint
New Zealand
On the Osmo Plus when you hold it in torch mode it will turn with the handle, not sure if this also applies to the X5.
2016-12-11
DJI-Thor
Flight distance : 13602 ft
In the setting, gimbal, you can change tracking speed, so the camera will follow your gimbal's direction more closely
2016-12-11
B1gfoot
DJI-Thor Posted at 2016-12-11 23:01
2017-1-3
breezeway95
Flight distance : 826854 ft
Keep your finger off of the trigger lock. If you aren't holding the trigger lock then you can change the gimbal settings to react more quickly to your movements.
2017-1-3
