P4P gimbal horizontal adjustment
10795 37 2016-12-13
Zaunz
Flight distance : 72621 ft
Anyone else having an issue with the gimbal facing to the right by a degree or 2.
I have done all the calibrations and all firmwares are up to date. They have the gimbal roll setting but they need to add a horizontal adjustment.
Everything in the status menu is on normal
Like its no big deal but when you pay enough for the phantom you would like everything to be pretty good. I'd add a photo but you would never tell the difference without seeing in person
2016-12-13
Hi Zaunz, please post a image here and we can help to check it.
2016-12-13
Murat82
Flight distance : 311385 ft
Finland
DJI MINDY, here also same problem! btw my camera is looking to left...
2016-12-13
Zaunz
Murat82 Posted at 2016-12-14 01:57
yeah mine isnt that bad. probably half of yours but in the other direction
2016-12-13
Zaunz
DJI Mindy Posted at 2016-12-13 22:22
Here is a video. still hard to show but if you look close enough when i have it in FPV mode i can hold stick fully and it goes into the correct position but when i let go it goes back out to what it thinks is zero
2016-12-13
Murat82
Finland
DJI Mindy Posted at 2016-12-13 13:22
i added also picture if u guyz could check the problem..
2016-12-14
Murat82 Posted at 2016-12-13 22:57
Have you tried to do the IMU calibration and gimbal calibration?
2016-12-15
Murat82 Posted at 2016-12-14 17:23
Please manually rotate the gimbal in the opposite direction of the tilt until it reaches its limit.
Do this several times, and the gimbal should be centered.
2016-12-15
Zaunz
DJI Mindy Posted at 2016-12-15 21:34
i assume i can try this also. Do we try this with the phantom off?
Can you see what my phantom is doing from my video?
2016-12-15
Zaunz Posted at 2016-12-16 04:42
Yes, please try that method as well.
2016-12-16
Jusba31
Flight distance : 248169 ft
Finland
Having that same problem. Camera is showing left.
That's my third problem with p4p. First drone gimbal doesn't work, got replacement.  That one has dead battery and gimbal are not showing straight.This new one has also gimbal clicking sound problem ,when camera is tilting more than 90deg down.
I'm very disappointed with the quality that DJI has with that  4 Pro model.
2016-12-24
HellStream
Flight distance : 1370771 ft
Finland
Jusba31 Posted at 2016-12-24 21:04
I have the same problem with the gimbal. That clicking sound when camera is tilting more that 90deg down. Also my drone keeps quite buzzing noise. I think the "problem" is the internal fan.
2016-12-24
MeDrone
Flight distance : 1245548 ft
DJI Mindy Posted at 2016-12-16 09:51
I have the same problem as well!IF this will not work can i send it back for a replacemnet ?Is new.....
2016-12-25
MeDrone Posted at 2016-12-25 23:55
You could get in touch with our tech support and send it in for further evaluation.
Our engineers will help to evaluate it.
2016-12-26
visider
Russia
DJI Mindy Posted at 2016-12-15 02:34
My camera looks to the left. How I can center camera?
firmware upgrade and gimbal calibration does not help.
You written about the manual alignment of the camera. What is it?
2016-12-30
Please rotate the gimbal to the right by your hand until it reaches its limit.
2016-12-30
visider
Russia
DJI Mindy Posted at 2016-12-30 03:43
I have a soft power to turn the gimbal right when quadrocopter included?
2016-12-30
visider Posted at 2016-12-30 03:53
Yes, sounds right.
2016-12-31
visider
Russia
Dear Mindy, please see my short video from turning on the copter.
First, the camera looks straight ahead, afterwards turn slightly to the left. Probably, it is not a gimbal, which could shift during transporting. Probably the thing in the software of the camera
2016-12-31
sakumar
Flight distance : 239134 ft
"I have a soft power to turn the gimbal right when quadrocopter included"
What does this mean? Should the power to the Phantom 4 Pro be on or off when I manually try to turn the gimbal in the opposite direction?
2016-12-31
Con Seannery
DJI Mindy:
Can you please give us an update as to if and when DJI will issue a fix for the many, many people who are pointing out the high wind warnings in their P4Pros even in no wind conditions? Many of us have sent logs, screen captures, reports, emails, etc.  Now DJI doesn't appear to be issuing anything or even acknowledging this obvious bug at all.
What is going on?
2016-12-31
sakumar Posted at 2016-12-31 11:12
I think what he means is small strength.
You need to do that when the aircraft is turned off.
2017-1-3
Con Seannery Posted at 2016-12-31 12:17
DJI Mindy:
Hello, I didn't receive your flight data.
If convenient, please upload the flight data to dropbox and send me the link.
2017-1-3
visider Posted at 2016-12-31 07:25
camera phantom 4 pro
If still no improvement, please get in touch with our tech support at support.eu@dji.com.
2017-1-3
user1c2605e346
Flight distance : 1563980 ft
Doesnt make sense dji mindy to "move the camera while off" what in the world will that do? And powered on def doesnt sound like a good way to do it either....with these little problems with gimbal such as clicking and etc dji needs to really look at this while on the assembly line. There is some bugs that need ironed out like the rth bug, dead battery on arrival, the gimbal problems, map problems also....etc when will dji give us tge firmware update to fix this stuff these quadcopters are not cheap! One expects some problems on a few units but there have been numerous accounts of these bugs it sucks! No one wants to send their unit away for 2 to 3 weeks because of this and it seems alot of people have to! I love dji products but cmon this is getting old plz fix this beautiful machine
2017-1-3
sakumar
user1c2605e346 Posted at 2017-1-3 04:14
Make sure the Phantom is off. Grab the gimbal below where it is attached to the aircraft and gently twist it in the opposite direction to straighten it out. I twisted it past where I felt slight resistance (that is to say, past the end point). After that, when I powered on the Phantom, the camera was aligned and pointing exactly forward. Other people have reported that it took several iterations (power-off, twist, power-on) and eventually they got it straightened out.
2017-1-4
calmax
The twisting method fixed my off centered gimbal.  Thank you.
2017-1-26
dirtdroner
Flight distance : 3633799 ft
Mine has been left for a while too. I did gentle twists to no avail. I guess I'll get a little more manly with it and see how it goes. Mine is bad enough that FPV flying down low and tight is almost out of the question with any speed at all.
2017-1-26
fans1d27569c
Flight distance : 46614 ft
My p4p did all of these it also flew to the right and one motor was getting hot. I've since downgraded my firmware and its now all good. Good luck and hope this works for you
2017-1-26
Dunning
Flight distance : 3673593 ft
I have had 3 P4Ps now that have is misaligned camera. I've tried twisting them with power off. I've tried disassembling the entire gamble to see if there was some kind of adjustment. Nothing has worked. Then I found a guy that posted that there is some kind of setting in DJI Go 4 app. Once you connect you P4P to your device the setting will disappear. I'm not sure why DJI takes this setting out. Here is a screen shot.
2017-2-26
Dunning
Dunning Posted at 2017-2-26 08:20
I have had 3 P4Ps now that have is misaligned camera. I've tried twisting them with power off. I've tried disassembling the entire gamble to see if there was some kind of adjustment. Nothing has worked. Then I found a guy that posted that there is some kind of setting in DJI Go 4 app. Once you connect you P4P to your device the setting will disappear. I'm not sure why DJI takes this setting out. Here is a screen shot. [view_image]
Having trouble posting the pic.  Just go to this thread at PhantomPilots.com
http://www.phantompilots.com/thr ... ji-go-4-app.107970/
2017-2-26
fans87181c06
I tried the twisting the gimbal trick and it seems to have worked on mine
2017-2-26
fans26f6c207
Flight distance : 3222126 ft
I was skeptical about this method, but I can confirm it worked for me 100%,  just rotate in the opposite direction of the tilt without force it too much.
2017-10-1
fanse1dc2931
Flight distance : 166896 ft
Philippines
fans1d27569c Posted at 2017-1-26 14:47
HOW did you downgrade your P4P firmware please? I see no options for any other firmware versions except for the current one V1.04.0602 on both my DJI Assistant and DJI Go 4 app. I saw on youtube that downgrading to an earlier version will fix my limp gimbal issue on the P4P.
2017-11-9
fans51ffc175
Having same issue, but to the left slightly
2017-12-5
fans51ffc175
What does the "Gimbal Centering" feature in the DJI Go App do specifically and how are you supposed to use it?
2017-12-5
jay 301
Flight distance : 1286 ft
Suriname
https://www.youtube.com/watch?v=BwUH8tAId54
2020-3-9
jay 301
Suriname
can antone help me with this... see link above
2020-3-9
