Inspire 2 - stress tests
1083 6 2016-12-13
Alex Assenmache
Flight distance : 216430 ft
Hi guys, we thought that apart from doing a review, we could starting to do some interesting tests on the new inspire 2. Let me know what you think! thanks
2016-12-13
fansa84fe8a4
Flight distance : 3 ft
Interesting.
How about doing some straight and levels for a distance over flat-lands or water - or until the battery is nearly dead - and seeing how the barometer performs and if the altitude is correct on landing?
I thought I read this had multiple redundancy so it should be more accurate than the P3, P4, and maybe P4 Pro?  I saw when you landed it was reporting a negative altitude from takeoff, and the P4 Pro seemed better.  My old P4 is so far off (18 meters) after a 2,000 meter run it's disconcerting to try and determine a safe clearance with ground objects at times.
2016-12-13
Donnie Stugots
Flight distance : 3636782 ft
How do you get these for review, I mean I would much rather have you than that Casey dude....just wondering.
donnie
2016-12-13
DJI-Jamie
Flight distance : 112405 ft
fansa84fe8a4 Posted at 2016-12-14 00:30
Interesting.
Since it was only off by .1, it could be that the ground was slightly uneven and that it landed on at slightly lower point, than where the home point was initially recorded.
2016-12-13
RichJ53
Flight distance : 1837356 ft
Interesting tests but it would be nice to see normal flying conditions and battery life etc.
Guess it would be nice if DJI sent me the Inspire 2 for testing and evaluation
Rich
2016-12-16
R&L Aerial
Flight distance : 298100 ft
How did you get one of these????
2016-12-17
Farnk666
Flight distance : 1711394 ft
So it seems that the DJI Marketing department are in high gear for the Inspire 2.
Generating hype at all costs - no actual 'testing' of the Inspire 2 in real world application or use cases.
Also, why the hell would you test an Inspire 2 against a phantom? Completely and utterly pointless.
Here's an idea - why don't they get some review units into the hands of some of the professional users here on the forum like JimHare?
If it is a platform for pro cine users, then lets see it being used as intended!
2016-12-17
