Possible problem with one motor
695 8 2016-12-13
andrewlcc
Czechia
[ Last edited by andrewlcc In 2016-12-13 20:15 Editor ]\n\nHi all,
I need your help
I bought my P2V+ and everything works fine..today i make some great videos.
But not the all blades are spinning like they should. When i turned off the motors there is one of these which turn off a little bit earlier.
And also when i start Phantom the ESC LED on one of these motors is turned off, but when i add a little bit throttle the LED its on !!!
anyway, like i said, the flying is fine..no problem at all..
can you please help me or give me some advice?
thank you very much
Andrej
PS: my english is bad...sorry for that
2016-12-13
DJI Natalia
Flight distance : 318 ft
Andrej, please try to rotate the motor with your finger to check if anything abnormal?
Then you could hover it at a lower altitude to see whether it can keep stable.
2016-12-14
andrewlcc
Czechia
Hi Natalia,
I check motor rotation with my hand but there is nothing abnormal..just a little bit resistance of that motor. (Front CCW)
And when i try hover at lower altitude its also stable..no problem at all. Maybe that motor its just a little bit hotter than other motors.
Maybe its caused by a stronger bearings ?
Thank you
2016-12-14
Labroides
Flight distance : 9991457 ft
If it's flying well, there's no problem.
It's normal for a motor to appear to shut down after the others.
2016-12-14
andrewlcc
Czechia
Thank Labroides,
Yes, it´s flying very well..but i am worried about that front LED diod from ESC. If i powering up motors the LED diod is off..but when i add a little bit more throttle to that motor..ist on.. and LED diod now working very well.
2016-12-14
Harbourside
Flight distance : 6467 ft
I think to be safe (as a ESC failure means crash) I would change the ESC and if the motor does feel stiffer than the others I would change that as well.
You could always open it up and check the wiring to and from the ESC first.
2016-12-14
andrewlcc
Czechia
yes i open it up few days ago..everything looks good..i check wiring and seems good..but i just realize...when i power up motors that one motor sound diferent in iddle...(ESC light is off)..then when i add throttle(ESC light is on) sound is same as others.
2016-12-14
BillW50
I won't chance it. I would replace that motor and there is a good chance everything will be fine after replacement. If not, then it looks like the ESC. If you want to save money, just swap the two CCW motors and see if the problem moves to the back. Then you would know for sure.
2016-12-14
andrewlcc
Czechia
Thanks for advice..here is a link to video..just to be sure
2016-12-14
