DJI Go 4 latest Update faulty
2074 12 2016-12-14
henk0
Hey there,
the latest App Update (released 12/14) for iOS has problems with missing Texts / Translations.
The App is only showing strings. Please fix!
Tested on iPhone 7 Plus with 10.2.
Greetings
Hendrik
2016-12-14
RoryM
Flight distance : 291106 ft
App is loading OK for me on iPhone 6S with iOS 10.2
I haven't flown with the new update just loaded the app.
2016-12-14
Mariooo
Flight distance : 254537 ft
only the german language setting is faulty
2016-12-14
DJI Natalia
Flight distance : 318 ft
Hi Hendrik, we've checked it on our IOS device, and did not find the issue you mentioned.
Please try to restart your device and download it again. If still the same case, please post a screenshot here, thanks.
2016-12-14
R&L Aerial
Flight distance : 298100 ft
It's best to sync your flight records then delete the go app then do a fresh reinstall, I always have problems updating but this works every time.
2016-12-14
Mariooo
DJI Natalia Posted at 2016-12-14 13:12
No german text files in this new version Re-installation did not solve the problem
2016-12-15
XIC9UreWyjkP
I have the same problem !
2016-12-15
gnom
Flight distance : 716572 ft
Its a language problem. Stellt auf englisch um dann geht es wieder ;-) In english everything is perfekt.
2016-12-15
NikolasB
Ups, I can't schpeek Änglisch
2016-12-15
DJI-Ken
Flight distance : 1515312 ft
Mariooo Posted at 2016-12-15 01:44
[view_image]
[view_image]
What exactly is the issue, I'm comparing these three screenshots to the English version and what German text files are you talking about.
2016-12-15
nils.heidorn
Flight distance : 183537 ft
DJI-Ken Posted at 2016-12-15 19:27
Ken, you need to set your iOS device to German and restart DJI GO 4.
Easy to replicate that way.
It displays the Translation tokens used in development instead of the translation strings, probably the ".lproj" files are missing or something trivial.
Nils
2016-12-15
DJI-Ken
nils.heidorn Posted at 2016-12-15 11:42
OK, I see. I've sent a message to R&D.
2016-12-15
fans093fc0b7
Flight distance : 514373 ft
I am using an iPad mini4'with go 4 and I am trying to change the max elevation and distance in the settings. When I tap in the box to make the change the numeric keyboard pops up and I can change the number but there is no way to save the changes. The keyboard only has numbers, delete and Undo, copy and past buttons. In addition once the keyboard is open the only way to close it is by closing the app and restarting it again.
Is this an app issue or am I missing something?
2017-1-3
