Gimble won't go up past 90 degress
1080 4 2016-12-14
charlesbcraig
Hi, at some point my gimble stopped letting me raise it above 90 degress to the max of 120. I used to be able to do that, so I figure I must have changed a setting by accident. Any advice on this?
2016-12-14
A56kuser
its in the gimbal setting then hit advance setting
the turn off "Enable upward gimbal tilt limit to 30 degrees"
2016-12-14
Heavysledz
Flight distance : 819491 ft
if you did a firmware update or APP update, I believe it defaults the settings so it could have reset this setting.
2016-12-14
charlesbcraig
Heavysledz Posted at 2016-12-14 15:52
Ah that makes sense.
2016-12-15
4wd
Flight distance : 545817 ft
It didn't reset mine at firmware update but inconsistency is the norm with such things for some reason.
2016-12-15
