aircraft now power-up
667 6 2016-12-15
stefansegers
Hi guys,
I wanted to start the aircraft but it did not power-up at all. The battery is full.
I tried to upgrade firmware after that and this failed too.
I can't get anything to work anymore
My Drone is the Phantom 3 standard
I am a nooby so I really hope somebody can help me out here? I tried everything in the FDirmware Upgrade PDF but none worked
Stefan
2016-12-15
BillW50
Did you watch these videos?
http://www.dji.com/phantom-3-standard/info#video
2016-12-15
DJI Natalia
Flight distance : 318 ft
Sorry to hear about the issue.
May I know how long you've owned it? when press the power button, how about the LED status?
Please press the button, release it then hold it for 2 seconds, then check again.
If still the same case, it would be best if you can record a small video here.
2016-12-16
Geebax
Are you using the correct starting procedure? Press the power button on the battery and release, then press it again and hold it down while the LEDs march across the front of the battery and it should switch on.
2016-12-16
stefansegers
Hi and thanks for getting back to me!
I tried to click and hold the power button for 2 seconds and then it looks like it will start but then battery goes off. After that I also tried to hold the power button, but then 4 lights come up and battery will go off again.
2016-12-16
Ciro Italy
No...you must press battery button one time 1 sevond....then release it AND PRESS AGAIN ...it start
2016-12-16
stefansegers
Hi Ciro, wow that did work.. Tried it a few times before ... now finally it works!!! Very happy!
2016-12-17
