vfrailing
Flight distance : 2564442 ft
Has anyone else experienced this? To get the most out of the camera, I usually shoot raw, and use AEB for 5 different exposures. I am getting 2 strange things. Even though the 5 images are clearly at different exposures, when I upload them to Lightroom and then export to Photomatix to combine, I notice that the exposure data is all same for all 5 images. Again, this is not correct, because there is clearly a change of exposures in them (I estimate 2/3 of a stop).
Then, if I use batch process in Photomatix, I get really bad barell distortion created in the merge. However, if I do it one at a time, there is no problem. ( When I do this, I do have to hand enter .67 exposure change, because it says the exposure data says they are all the same, again, incorrectly)
Weird. I called DJI and told them about the metadata issue, and they recorded what I said, they had not heard of this issue.
Other than that, mostly happy with the images. If you want, I can send images.
