Mavic charging hub not working
1492 8 2016-12-17
dixieandbacon
No lights nothing . Tried to update nothing
2016-12-17
DJI-Ken
Flight distance : 1515312 ft
Are you able to upload a quick video clip.
If your batteries are close to full, they need to be powered on to take a charge.
If they are not then there may be an issue with the hub. Does the AC adapter charge your battery when plugged directly into the battery without the Hub ?
2016-12-17
dixieandbacon
Yes my charger will charge a single battery just fine . All the batteries are very low . When I plug in the Hub I don't even get a status light . I will make a short video and upload it . I just received my package today
2016-12-17
dixieandbacon
https://drive.google.com/open?id=0Bx_FQmNMIYk7eFBaMGU1TFplSkU
2016-12-17
EdM
Flight distance : 1491814 ft
Norway
Mine does the same thing.   Sometimes if i leave it alone for about 10 minutes a battery will start charging.   When it finishes after a while another will start.    Batteries charge fine if only connected to the charger.
2016-12-17
dixieandbacon
So your status light on your charging hub never lights up when you plug the power adapter into it ?  My status light on the hub doesn't come on at all
2016-12-17
dixieandbacon Posted at 2016-12-18 14:24
I've checked your video. One of the batteries is seems like close to full.
Have you tried to dis-charge it and then use charging hub to charge it again?
Or as EdM mentioned, have you tried to leave it for a while?
If still no improvement, I'd suggest you to send it in.
2016-12-17
dixieandbacon
I've tried everything nothing is working . How do I go about sending it back ? And what would be the turn around time to get another one ? I just received it yesterday and it has never worked
2016-12-18
dixieandbacon Posted at 2016-12-19 03:10
Please send an e-mail to support@dji.com with the following info, the subject should be " Forum support" . We'll help you create a case.
Case illustration:
Country:
Full name:
Email address:
Phone number:
Shipping Address:
Zip Code:
Forum link for your case:
2016-12-18
