Quality issues after FW upgrade on P3P
791 14 2016-12-18
Benjamin Watson
Flight distance : 42864 ft
Denmark
Hi all.
I´m the happy owner and new to the P3P so i need some help with an issue i experience.
I´ve been trying to learn to fly my new drone and yesterday it prompted me before take off to update both the controller and my P3P.
S i read through the guideline on how to do this an it appears fairly simple.
Updated the controller with no issue, then went to update the aircraft. The update took forever and it failed in the end.
Upon restarting the aircraft all i got was error beeps from it and no indicator lights at all.
Then i tried to DL the FW again tried several times. Finally it seems like it was updating. However, now i have problems with it loosing connection to the remote and the image is flickering constantly.
Also when i look at the battery info in the GO app it looses the info and the it comes back online again.
Is there a way to force the FW upgrade again to ensure that its updated correct and how do i update the batteries?
I tried to do the same process on each battery but it seems that they are updated which is strange.
Looking forward to you help and inputs.
BR
Benjamin
2016-12-18
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Maybe you can try to relink your remote using dji go app to your p3p.
2016-12-18
fans82a39c9b
Thailand
Did you update the firmware on the drone itself by downloading the .zip file from the DJI website and then extracting the .bin firmware update file, putting it in the root directory of the memory card and then turning the drone on with the memory card in and the remote control (RC) turned off and letting it go through the update process?
Have you tried re-linking the drone to the RC? this may solve your connectivity problems - you can do this through the DJI Go App.
2016-12-18
Barney Rubbel
Make sure you remove the upgrade file you put on your SD card before trying to restart. Sounds like you did, but thought I'd throw it out there. Good luck!
Barney
2016-12-18
Benjamin Watson
Denmark
Hi all.
Thanks for your quick reply.
I just tried to re-link at you mention and i also double checked that the .bin file is removed on the SD however it´s exactly the same result.
Please see this video to see how I experience it.Sorry about the sound
2016-12-18
Nelsonlee
Malaysia
Benjamin Watson Posted at 2016-12-18 22:29
Hi all.
what is your current DJI Go app version and RC version?
If your RC current version is running on V1.8.0 then i advice you downgrade it to V1.6.0
2016-12-18
Benjamin Watson
Denmark
Everything should be upgraded with the newest fw.
App: 3.1.1
Version: 1.10.90
RC: 1.8.0
I guess these should be the correct versions right? Maybe the newest one are "buggy"?Btw. Can´t find rev. 1.6 online. only rev. 1.8 & 1.9. Also i don´t see a guide on how to dowgrade the fw. Is it just the same way as when i upgrade?
2016-12-18
Nelsonlee
Malaysia
Benjamin Watson Posted at 2016-12-18 22:46
App: 3.1.1
I have put the video to guide you how to downgrade your RC 1.8.0 to 1.6.0
You just follow the video step then you will get 1.6.0 RC firmware.
2016-12-18
Benjamin Watson
Denmark
Nelsonlee Posted at 2016-12-18 15:54
Thanks, will try that out now.
To be sure, the aircraft shall still be rev. 1.10.90 right? It´s only the RC that i´m downgrading if I understand you correctly.
2016-12-18
Nelsonlee
Malaysia
Benjamin Watson Posted at 2016-12-18 22:57
Once you upgraded to V1.10.90 and you can't downgrade it, DJI already mentioned on the thread post.
You only can downgrade the RC and dji go app....
2016-12-18
Benjamin Watson
Denmark
So I finally finished the downgrade of RC and so far it seems to have worked.
At least when testing inside my house.
Will test tomorrow outside if the weather allows it.
Thank you very much. I'll keep you posted.
2016-12-18
Nelsonlee
Malaysia
Benjamin Watson Posted at 2016-12-19 00:01
I also just test inside my living area because here raining day can't get outside for test fly.
2016-12-18
Benjamin Watson
Denmark
Dear all.
Thank you very much for your help.
It worked perfectly. Flew outside yesterday and everything is fine.
2016-12-19
Nelsonlee
Malaysia
Benjamin Watson Posted at 2016-12-20 14:10
Dear all.
Great to hear that...
2016-12-19
fans98a4fa0d
Flight distance : 202126 ft
I had this same problem.  Two things seemed to eliminate the pixel-ating.  Waiting till both the RC and the Bird were turned on before plugging the cable in to the iPad mini and turning off wi-fi.
2016-12-19
