Battery never turns off when fully charged
747 3 2016-12-19
ty5
My battery will charge until I get the full 4 LEDs, but it never turns off.  The other battery I have charges to 4 full LEDs and then turns off.  Is this a faulty battery?
2016-12-19
4wd
Flight distance : 545817 ft
It sounds like the final balancing is taking a long time, have you tried leaving it for several hours?
If it seems normal in use, running it down below 10% then recharging might fix it.
The seller would probably replace if you described your concerns.
2016-12-19
Kep1
Flight distance : 255984 ft
China
Stupid question, but did you try to turn it off?
2016-12-19
Could you please make a short video of this issue? When you put the battery into the aircraft, is there any error message shows up from DJI GO app?
2016-12-20
