MY iPHONE 6 is CHARGING the CONTROLLER!!
2607 17 2016-12-21
Tonold
I've read about the battery issues with the iPhone 6's and the DJI Go app when flying the Mavic (http://forum.dji.com/thread-16028-1-1.html).
Well, I just upgraded to an iPhone 6 myself and it looked like I was encountering the same problems - my phone battery dies after about 30 minutes of flying. But today I noticed I might be having a different issue than the one described in that thread above.
I was using the most up-to-date version of the DJI Go App before, and I was assuming this was a problem with the app, so I thought I would try using other applications to avoid the problem. I tried an older version of the DJI Go App (3.0.2) I had saved on my computer. I tried the DJI Go 4 app. I tried Litchi App. In all instances, my phone's battery died in less than an hour of flying. It was just after my most recent testing session that I noticed: The Controller's battery was at 100% after 20 minutes of flying!!!!!! (and my phone's battery had dropped from 96% to 23%).
THE PHONE IS CHARGING THE CONTROLLER.
Why is this happening? There has to be some mistake in the current software for the controller that makes it recognize the iPhone 6 as a power source. The controller then sucks the phone dry (the controller should be the one charging the phone).
I don't know if I'm the only one with this issue. Perhaps this is really the problem being had by other iPhone 6 users, maybe they've missed some of the signs and incorrectly diagnosed the problem. Perhaps it only happens sporadically, making it even harder to notice and further confusing the other issues people are having.
Regardless, this is something that needs to be fixed. I can't go out and film anything, because the phone doesn't last long enough to make the trip worth it without carrying multiple battery banks to recharge the phone.
Has anyone else noticed this issue? Has anyone heard from DJI about it? What can we do about it?
2016-12-21
FrequentFlyer
Isnt there a recall on the iPhone6 battery's?
2016-12-21
dana5
Flight distance : 14354 ft
FrequentFlyer Posted at 2016-12-22 02:31
Feels like there should be a recall on the iPhone in general... But to each their own.
2016-12-21
DJI-Ken
Flight distance : 1515312 ft
I do not think your phone is charging the RC. The RC says "Charging" if it's being charged.
You can test it by running the RC down a little, then connect your phone and see if your RC's charge % goes up.
If that is what's happening, please pst a video clip.
2016-12-21
FrequentFlyer
dana5 Posted at 2016-12-21 10:39
No need for negativity, as your response is no help to the OP.
2016-12-21
z4k4tt4ck
Flight distance : 535 ft
FrequentFlyer Posted at 2016-12-22 03:14
No need for a response to negativity, as your response is no help to the OP.
2016-12-21
James L.
I use iphone 7 plus and it went down 7% after about 15 minutes of flying flying today.
I started 100% and I was at 93%.
Edit: I checked the flight and it was 12 minutes.
2016-12-21
James L.
When I had the P4, I used a ipad mini.  I remember it used less than 1% per minute of ipad battery.  It's been about the same with the Mavic and iphone.
I still carry an external battery just in case.
I fly at the brightest screen setting.
2016-12-21
High Flyer
Flight distance : 944642 ft
I thought I had an issue with my P4P as the controler power ran down too fast. Reason ? the controler is charging my ipad
2017-1-3
High Flyer
DJI-Ken Posted at 2016-12-21 10:48
My P4P RC is charging my iPad pro which really surprised me. Its also rather annoying as my RC is only lasting half as long as my P4 or P3P RC used to.
Question 1 is : Can I stop the RC charging my iPad ?
Question 2 is : Can I connect an external battery to my RC while flying to keep everything charged ?
2017-1-3
4wesomeAdam
z4k4tt4ck Posted at 2016-12-21 11:21
No need to respond about a response to a negative response which is no help to the OP.
2017-1-3
Schwavic
Meaningless, out of place blanket statement with nothing to back it up...  Makes sense.
2017-1-3
UtopianCrew
Flight distance : 5213 ft
I don't have my problem. Are you plugging your device into the USB port on the bottom of the controller?
2017-1-3
DJI-Ken
High Flyer Posted at 2017-1-3 15:59
Do a test, fully charge the RC then power it on and plug the iPad in. You will see that if it charges it is a very low rate that does not take much power from the RC.
Test for 20-30 minutes with the iPad plugged in then unplugged and see the percentage difference the RC has after testing.
2017-1-3
UtopianCrew
I do not have these problems.
To help you, I have done some testing.
Using the side connector or bottom connector, the remote does not charge with the following devices:
iPhone 6
iPhone 6+
iPhone 6S
Hope this helps!
2017-1-4
Jason Lane
Flight distance : 260144 ft
Philippines
Are you using cable supplied by DJI, or a different cable? Any chance you're using some kind of OTG cable that allows the iPhone to charge other devices? (I don't even know if it's possible)
Are you using the or bottom port on the RC? Try the other one and see what happens. Make sure to completely disconnect the cable from the side port if you're using the bottom port.
Is it extremely cold where you're flying? I think I've read of some iPhone 6 phones going dead in cold weather.
2017-1-4
fanse0c91dbf
I'm having the same issue with my phantom 4 ... the iPad is draining much faster than normal use .. (approximately 2 hrs of use drains to single didgets when connected to the RC) I also have a phantom 4 pro and this is not an issue the iPad remains topped up by the RC all day (approximately 6-8 hrs of flying causes the RC to drain 50% while my iPad remains 98-100% ) this has been an issue for me since the last updates. (Worked fine in January)
2017-2-21
alirz5
Flight distance : 609833 ft
off topic but i know for Android devices, the RC charges the phones. At least it does in my case. I have Nexus 6P USB C phone. and there seem to be no way to disable that.
I think we need data only cables, that dont have the pins in them to supply power!!! That ought to take care of this non sense of RC charging the phone...
2017-2-21
