charging
fans397ed003
Can you charge battery and controller at same time??
2016-12-23
Barney Rubbel
From my understanding, it is not advised. It can overheat the charger. I can't vouch for multi-battery chargers, but I believe the manual tells you not to charge them both at the same time.
2016-12-23
Barney Rubbel
From my understanding, it is not advised. It can overheat the charger. I can't vouch for multi-battery chargers, but I believe the manual tells you not to charge them both at the same time using the DJI charger.    Barney
2016-12-23
DJI-Jamie
Flight distance : 112405 ft
It can be done, but it's not recommended as Barney indicated.
2016-12-23
AG0N-Gary
Flight distance : 700846 ft
It is not advised by DJI.  I'm guessing it may mess with the balancing of cells, as well as taking longer of course.
2016-12-23
DJI-Jamie
AG0N-Gary Posted at 2016-12-24 12:01
It's more of an overheating issue than anything else.
2016-12-23
AG0N-Gary
DJI-Jamie Posted at 2016-12-23 23:22
Not unless the charger is more than double the capacity needed to charge one of them.
2016-12-23
fansea8ff0df
Flight distance : 14715 ft
In the manual it says no as this could cause charger to over heat.
2016-12-24
