So, this just started happening today....
1379 10 2016-12-23
13MStang
Flight distance : 892749 ft
see this video.    It just started happening today.   Mavic has never crashed.
things I've done to try to fix:
- replaced all 4 propellers
- Recalibrate compass
- Recalibrate IMU
- used different battery
- Checked gimbal
- checked motors.  they seem to all be proper and free
2016-12-23
trance728-
Flight distance : 298048 ft
Your Mavic is having a seizure. Maybe you could try downgrading the firmware and then re-updating it and see if that fixes it.
2016-12-23
Scunna
Your gains are to high, one of motor wires is loose ( single phasing)
2016-12-23
13MStang
Scunna Posted at 2016-12-23 11:16
thanks for the response.   I don't recall doing anything with the gain settings, but i am going to try to reset back to factory settings.
2016-12-23
Crusader
Check this out http://mavicpilots.com/threads/n ... lently-solved.3074/
2016-12-23
13MStang
UPDATE!!!!   FIXED!!! ( i think )
I connected the drone to DJI Assistant and did a "Restore to factory settings" and that seems to have corrected the issue.
My theory is this:
I did use a different phone yesterday evening for the first time.   my "normal" phone was low on battery so i borrowed my wife's phone, installed DJI go 4 on it and used it for 1 flight.  Today, when i went back to my normal phone, the issue started happening.  Both phones are the same (iPhone 6s).
So i think that whatever settings I made to DJI Go on my normal phone did not transfer over to my wife's phone, so when i switched back, things my have gotten screwed.
on my normal phone, i had made changes to the exp settings for yaw and also gimbal control settings as well.
This leads me to wonder about changing settings and THEN changing devices (iPhones, iPads, etc).
hmmmm
2016-12-23
DJI-Ken
Flight distance : 1515312 ft
13MStang Posted at 2016-12-24 00:53
Glad you got that sorted out, it does seem something happened when switching phones since that's when it started happening.
I was going to suggest a factory reset and refreshing the firmware.
2016-12-23
Willik
Flight distance : 638796 ft
Czechia
13MStang Posted at 2016-12-23 17:53
Thanks for solving this, marking down if anything similar happens to me in the future.
Cheers
2016-12-23
R&L Aerial
Flight distance : 298100 ft
13MStang Posted at 2016-12-23 11:53
I wouldn't jump for joy just yet, my mavic flys great sometimes and other times it does not.problems like yours will return so be careful
2016-12-23
coltsfan94
Can someone please explain how to restore to factory settings because this is happening to em as well. I didn't switch devices or anything so I'm not sure why it started on mine.
2016-12-23
13MStang
coltsfan94 Posted at 2016-12-23 18:00
you need to install DJI Assistant onto your computer and then connect the drone to the computer with the app running.  there is an option within the app to restore to factory settings.
2016-12-23
