1-2-3-4 1-2-3-4 batt leds
812 15 2016-12-23
JACKODOG-ANDROI
Flight distance : 208383 ft
just out of curosity i turned on p3 battery pliged in to charger leds blink 1-2-3-4 over and over,
does anyone know what the battery is doing?  ballancing cells maybe?
2016-12-23
DJI-Ken
Flight distance : 1515312 ft
That means the battery is charging.
2016-12-23
Hawks100
Flight distance : 134580 ft
Do you mean, 1 bar- 2 bar- 3 bar - 4 bar  back down to 1- bar. Thats charging.
Or
Do you mean all four bars flashing at the same time?
Have you let the batteries cool down before trying to charge?
2016-12-23
JACKODOG-ANDROI
Hawks100 Posted at 2016-12-23 12:27
Or
battery was full charged 12hrs ago. turned battery on and pluged in to charger
1 bar- 2 bar- 3 bar - 4 bar, all off  1 bar- 2 bar- 3 bar - 4 bar, all off  1 bar- 2 bar- 3 bar - 4 bar, all off
did this for 10min now all is off just wondering
2016-12-23
Hawks100
These intelligent batteries do self discharge so as not to store fully charged batteries.
In the Go App you can change the time that a battery will start to discharge.
It sounds to me that the batteries have self discharged a little bit in 12 hours and are getting charged back up to full.
This will start to add up to a complete battery cycle count if you keep doing this.
Why fully charge and then plug back into the charger tho? Are you just topping them up to fly??
2016-12-23
JACKODOG-ANDROI
Hawks100 Posted at 2016-12-23 12:49
i decided not to fly one more time last night, the battery was up to 4th led blinking when i un pluged.
this morning i knew the batt was not fully clarged so i put on charger and nothing happend,
so i un pluged batt and turned on battery [doubble push] and pluged into charger and got
1 bar- 2 bar- 3 bar - 4 bar, all off  1 bar- 2 bar- 3 bar - 4 bar, all off ,
was'nt acting like when charging,
2016-12-23
JACKODOG-ANDROI
JACKODOG-ANDROI Posted at 2016-12-23 12:59
gust put diffrent battery on, it was charging,
must have just woke battery up by turning on
sorry bout wasting your time.
Merry Christmas Everyone!
2016-12-23
Hawks100
When batteries are fully charged,all lights go out.
So you un-plugged the battery before fully charged(lights on the battery) then plugged back on the charger.It started to charge as it should.
Always fully charge a Battery from start to finish.
All the very best to you too.
2016-12-23
AG0N-Gary
Flight distance : 700846 ft
JACKODOG-ANDROI Posted at 2016-12-23 11:59
And that's where you went wrong.
When you prematurely removed the charger the night before, you interrupted the balancing process.  The battery charges and then it balances the cells afterward.  That's why it seems to "hang" when it gets to the 4th level.
When you charge, let it finish.  It will shut down when it is done.
Gary
2016-12-23
DJI-Jamie
Flight distance : 112405 ft
JACKODOG-ANDROI Posted at 2016-12-24 02:04
Sounds like you're good to go. Merry Christmas to you too!
2016-12-23
JACKODOG-ANDROI
AG0N-Gary Posted at 2016-12-23 23:18
what about when i get done flying and battery is 1 bar left and i let it cool but charge it to 2 bars and store.
not good?
2016-12-24
Hawks100
Are you putting it away for the next 5years?5months?5 weeks? Or just not using it for the next 5days.
In the Go App you can set after what time you want the batteries to self discharge. They will discharge naturally over a period of time.
I would fully charge, then store.
You need to forget about part charging these batteries.
These batteries are multi celled batteries. Each cell will get balanced(same voltage) charged at the end of the charging cycle.
This is very important to the health an longevity of your batteries.
Part charging will not be balancing each cell as the balancing fase happens at the end of the chaging cycle.
2016-12-24
JACKODOG-ANDROI
8 batteries, could be weeks or even months WINTER TIME!
So your advice is charge all to full and put away...
2016-12-24
Hawks100
Some would say charge them fully, then discharge.
I would charge them fully and let them discharge by themselves slowly.
People will have different views on this, Im sure.
2016-12-24
NicktheDick
Does anyone know what it means when the lights flash a couple of times then completely go off? Its like it starts charging then stops and restarts charging. Its only been charged 5 times before so its nearly new.
2016-12-25
AG0N-Gary
JACKODOG-ANDROI Posted at 2016-12-24 10:04
not good?
Not as good as fully charging it and letting it run down again.
2016-12-25
