G Davidson
Flight distance : 263465 ft
I had a look at your image on Google Maps and can see something that might be causing issues (the horizon, although wavy, is not centred half way up the image) - I suspect APG is not actually rendering a full 360 x 180.
It's important that APG renders a full 360 x 180 even if the sky is not there. You can force APG to render a full 360 x 180 by clicking on its crop tool and then "Full sphere (360 x 180)" and then the green tick (see attached screenshot). This should result in APG embedding the correct XMP data in the output image for you to then add the sky in PS.
However, I have heard reports of PS messing up the XMP data so the XMP template trick in that other link I mentioned earlier may still be of use
APG Screenshot
