Nigelbrinkmann
Flight distance : 577484 ft
JohnnyD34 Posted at 2016-12-25 21:02
I tried to charge the battery for an hour. It doesn't appear to be charging and the LEDs are still on. I put the battery in the Phantom 4 and it powers the P4. When I connect using DJI assistant and try to upgrade software I get an error saying battery needs to be over 50% charged. The LEDs are still permanentely on even after a full day. Will the LEDs go off when the battery eventually discharge? Should I put it in the P4 to fully discharge the battery?
Turn your battery on, then put it on charge, to see if that makes any difference when trying to charge it.
To turn on the battery push the button,then push and hold the button to turn it on, (same as you would to start the aircraft) |
